Riktar, congrats on your new purchase, and we appreciate you taking the time
to post your thoughts on both systems - I know we have a lot of folks thinking
about getting the D90 or D300.
I have a toddler, and the one thing that is limiting me with my K20D system
was low-light AF-lock speed - I really need to nail focus on a moving, bobbing
object in (usually) tungsten light. The K20D, depending on the lens, would often
be hunting and about 1/2 seconds behind the shot I needed to nail.
I decided to build a minimal Nikon system to specialize in fast-AF/indoor kid
shots, so I bought a D80, liked it quite a bit, and then just upgraded to the D90
last week.
My Pentax system is and will remain my main system, but in Nikon mount I now
have the 50 1.8 AF-D, 35 1.8 AF-S (on order,) Tamron 28-75 2.8, and Sigma
50-150 2.8 HSM II. I bought strictly low-light, fast-focus glass, because that's
what this system is for. Since it's not my main system, I have no need for
the extremely expensive Nikkor VR zooms, especially since the Tammy & Sigma
are such excellent alternatives (and I think your Sigma 24-70 2.8 HSM is going
to be killer-great also.)
I'll just throw in some thoughts below:
Originally posted by Riktar Well I am still waiting for my 24-70mm f/2.8 to arrive. So
I am going to start with some basic comparisons before getting into more
detailed analysis.
Hand holding: The camera compares the closest to my former D90 in size.
It is definitely smaller than the 40D and the SD14. I will be adding a grip to give
my little finger something to hold onto.
Agreed - very similar in size between the D90 & K20D. I find the K20D to be
more solid, with the sealing enhancements adding to the solidity (better doors,
etc.)
Quote: Focus speed with the Promaster (Tamron) 18-200mm lens: Under
bright/daylight conditions it achieves focus reasonably well. Compared to my D90
18-105mm VR lens it can be a tick or 2 slower but it still locks on reasonably well.
When you are going from extreme distance (focus point WAY off from previous
picture) it can do some hunting before it locks on. Indoors under basic light it
works ok. Under low light, well let me say that I have yet to use ANY camera that
locks focus in a heartbeat. And since I shoot events with an add on speedlight I
can use the infrared light from the flash to help the focus speed.
I think your Sigma will lock faster than that 18-200. My D90 system is faster
with every lens than the K20D with the corresponding lens. The Sigma 50-150
locks much faster than the DA* 50-135, (DA* 50-135 is sharper, though,) and
the Tamron 28-75 on the D90 locks faster than it did on my K20D (when I had
a Tammy in K-mount.)
It isn't a night & day difference, but it is significant, and it does mean that
I'm getting shots I missed before.
AF accuracy is still an open question - as you noted with your 40D, getting
focus lock doesn't mean much if its not accurate.
Quote: Menu system: Here is where this gets subjective. For myself I find the
menu system a bit tedious. Now I understand that the K20D has TONS of options
to utilize so finding all the stuff it can do is going to take some getting used to.
Over time I am sure I will figure out how to quickly get to the most common
functions. But in terms of being intuitive I think the K20D does a good job of
laying out all the stuff. To draw an analogy on this one could compare control
layouts in a car. That is to say that going from a Ford to a Toyota or Chevy is
going to involve learning where all the "new" stuff is.
Exactly right - and I'm coming at it from the opposite direction - the D90
menu system, while 'pretty', seems slower to navigate and less intuitive
to me - strictly for the same reasons you give above. I don't know where the
cupholders are yet so I keep spilling coffee on myself.
Quote: Noise: I shoot (99% of the time) RAW images so I can't speak about the in
camera jpeg engine. What I can say is the level of detail the camera captures is
more than the 40D and D90. This really shows up when I run my images through
Noiseware to clean them up. If you want to see a direct comparison yourself go
to
Imaging
Resource's compare page. After picking the D90 and the K20D use the
Still-life photos at 3200 ISO. If you run both images through Noiseware
Community edition (Freeware program) and compare you will find the K20D
images clean up just fine and have better contrast and detail then the D90. And
bear in mind you are talking about Jpeg images. Shooting in RAW will result in
images with even MORE detail since there will be no jpeg artifacts to contend
with.
Agreed - the K20D will capture a bit more detail than the D90 at high-ISO
(and you'll find this is true at low ISO too
,) but I'm really impressed with
the D90's in-camera noise reduction at this point - its less heavy-handed than
I've been led to believe. The CMOS sensor in the D90 is impressive.
(for the benefit of Pentaxians wondering about this, here's an
ISO 2000
shot from the other day (Tamron 28-75 @ 28mm, f/4) and crop below) :
Here's ISO 1250, with crop:
But shoot PEF, use noise-ninja, and there are few cameras better at low-light
detail than the k20D, but the D90 in-camera noise reduction and the resulting
jpegs are pretty impressive to me so far.
Quote: While I do have other comments I am going to hold off until after my daughter's
wedding which will be 2 weeks from today. The K20D will have a chance to strut
it's stuff under the lighting conditions/scenarios that I intend to use it in.
But for the moment I am more than pleased with my decision to switch to the
K20D.
The more you use it, and the more you allow yourself a little LBA (even for the
inexpensive MF lenses - the Green Button is something I really wish the D90 had,)
the more you'll come to appreciate the K20D. It gives me exquisite images
with a multitude of wonderful lenses. Last month I spent some time shooting
with a $25 Super Takumar 55 f/2 that
Blew me away, and the
M series are
extremely affordable, and great fun with great IQ.
In-body SR is a godsend - all these old lenses are VR to about 2 stops. And
the AF adjustment is huge - the D300 has it, the D80/D90 do not. With
the D90, I'm at the mercy of a lens being withing specs, but just slightly,
slightly off - with the k20D, this is adjustable, and all lenses that are shipped
to me within spec can be absolutely razor sharp with AF adjustment.
There are some holes in the Pentax lens lineup, more so than Nikon, but the
one area where Pentax really shines is small, affordable, incredibly great
prime lenses - the FA 31, 43, and 77, and the DA 21, 35 macro, 40 and 70
are without equal in the other mounts when you factor in IQ/size/cost. I
really suggest that you indulge yourself in that area.
