Originally posted by lesmore49 I'm thinking about getting a Pentax KM and the 18-55 lens, I would use it as a general carry around camera for every day use. I would also use it as a second body for my K10D.
What is the good....the bad....about this camera. Thanks.
I have tried the K-m for several times now with more than ten units. I can conclude the following:
- small, solid and well built
- AF is faster and smoother, with slow zoom, quite often there is hunting, but just for one to two times and it will stop. For fast primes, hunting will be less.
- exposure accuracy with kit zoom is not that good, especially at the 55mm side. There seems still some QC issue as I found that particular two units were "darker" than the other.
- with primes, the exposure accuracy is good, especially the
well-calibrated stop-down metering (as it seems to be)
- P-TTL is still not reliable, especially it could be unexplanably dark with the kit lens, more problematic at the 55mm side.
- jpeg quality is not of high definition, but its usable, depending on your requirements.
- Viewfinder image is bright, sharp and large (comparatively in its class)
- it is still AA battery type sensitive if you use NiMH, some batteries won't work for longer! You cannot use CR-V3 neither as the battery compartment will prohibit the insertion of CRV3 as intentionally designed.
Bottom line: at the same price as the Canon EOS 1000D kit, it is not a bad entry level choice. You have to decide what are more important for you, e.g., if direct out of camera jpeg and super sharpness is really important, you'd better choose the 1000D, say for example. Otherwise, the K-m still excels.
