02-15-2009, 10:09 PM   #1
"Focus by wire"?
Are Pentax DSLR lenses "Focus by wire", or mechanically focused when in MF mode?
[kurt]
02-15-2009, 10:24 PM   #2
Marc Sabatella's Avatar
QuoteOriginally posted by shuttervox Quote
Like virtually all SLR lenses, Pentax lenses are manually focused mechanically.
02-15-2009, 10:30 PM   #3
Blue's Avatar
[kurt]
I don't quite follow you regarding
Manually focusing is mechanical regardless of brand. Regardless of the autofocus mechanism and design, manual focusing requires physical turning to focus.
02-16-2009, 05:52 AM   #4
Albert Siegel's Avatar
I don't quite follow you regarding Manually focusing is mechanical regardless of brand. Regardless of the autofocus mechanism and design, manual focusing requires physical turning to focus.
Not quite... Most current Olympus lenses are focus by wire. The focus is not mechanical when you turn the focus ring. Even in manual focus mode, turning the focus ring on most Olympus lenses engages a motor that will focus the lens. Consider the focus ring more of a button you can turn like a jog-shuttle on an old VCR or video editing deck. There is no mechanical link at all.
02-16-2009, 06:36 AM   #5
rburgoss's Avatar
I believe Pentax SDM (only) lenses are also "focused by wire". There is no mechanical link between focus ring and focus mechanics. But I may be wrong.
Anyone care to test a DA17-70, off camera (no power), and turn the focus ring to check this?
02-16-2009, 07:23 AM   #6
Aren't those technically the same thing? When a pilot "flies by wire", he's got a direct mechanical/wire link to the controls and the parts of the plane he's moving.
I'll check out my 50-135 for the same thing though.
[kurt]
02-16-2009, 07:31 AM   #7
Jodokast96's Avatar
No, fly by wire has no mechanical link whatsoever. It's strictly electronic signals passed to the flight computers which then control what the plane actually does. Pretty much just like in a video game.
02-16-2009, 07:41 AM   #8
Presto's Avatar
My two DA* lenses (16-50 & 50-135) focus with no power and not mounted to the camera. The focus rings have a mechanical link to the focusing elements. They just have a clutch to disengage from the SDM motor when you turn the ring.
02-16-2009, 07:41 AM - 1 Like   #9
QuoteOriginally posted by legacyb4 Quote
Having a wire connecting you isn't the same as a mechanical connection. Turning/pushing/pulling a switch that directs electrical flow to a distant motor/controller/actuator isn't the same as moving the part yourself. Fly by wire could be taken a step further and be remotely controlled via wireless. It's more like using the remote control on you camera versus actually pushing the shutter button.
02-16-2009, 07:44 AM - 1 Like   #10
Blue's Avatar
QuoteOriginally posted by JavaJoe Quote
Regardless, with Pentax AF lenses the mf focusing is done manually. So are Nikon, Canon and Minolta.
02-16-2009, 11:54 AM - 1 Like   #11
falconeye's Avatar
It then would have to be called
"Fly by wireless" though
02-16-2009, 01:13 PM - 1 Like   #12
rburgoss's Avatar
QuoteOriginally posted by Presto Quote
I have no doubt about this two lenses having a mechanical link between focus ring and focus mechanism, since both can AF with any Pentax AF body, including film era bodies. What I am wondering is about the SDM ONLY lenses like the DA 17-70.
02-16-2009, 01:18 PM   #13
Olympus are focus by wire and I don't care for it on either model I own. Here are some reasons
1. Can't even manual focus without camera being on. Thought it was broke when I was playing with new camera first day. Batt was charging.
2. No close focus/infinity stops on lens. They just keep turning and turning.
3. Kit lenses are unsmooth feeling when focusing.
4. Kit lenses have no distance scales.
Sure there are more reasons.
thanks
barondla
Check out POINT & SHOOT CONTEST #15 WINNERS in P&S forum. Enter #16. Any brand camera. Enter now!
02-16-2009, 02:47 PM   #14
QuoteOriginally posted by barondla Quote
5. Makes camera feel like electronic toy rather than profession photographic equipment.
6. Focusing wears down the battery for no reason whatsoever.
02-16-2009, 03:01 PM   #15
Whoops, mixed that one up.
I defer to the comments on that!
QuoteOriginally posted by Jodokast96 Quote
camera, dslr, photography
K10D shutter will not "snap" but focus/flash work! PlumRT Pentax DSLR Discussion 9 01-13-2011 07:11 AM
Sports "Highside Exit" took 1st Place in DPReview "Missed It by THAT much, Part 1" Challenge MRRiley Post Your Photos! 27 02-21-2010 08:26 PM
What does "auto" mean on older manual focus lenses? jonhock Pentax SLR Lens Discussion 18 12-03-2009 11:32 AM
Intermittently working "Catch-in-focus" while using m42 screwmount lens shuttervox Pentax DSLR Discussion 1 08-06-2009 07:55 PM
"Hunger for a DA*50-135?" or "The DA*50-135 as a bird lens!" or "Iron age birds?" Douglas_of_Sweden Post Your Photos! 4 08-13-2008 06:09 AM
All times are GMT -7. The time now is 12:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
