02-17-2009, 12:05 AM   #1
Double/Multiple Exposures
Anyone know how i can get a double exposure of me sitting in two different chairs, ie as if i had a twin sitting next to me. I tried this once and found that both versions of me were see through. How can i get a full imprint of myself in double exposure mode?
I'm using a K20D.
02-17-2009, 12:30 AM   #2
pentaxmz's Avatar
QuoteOriginally posted by JohnnyDop Quote
I'm using a K20D.
Two ways with the K20D.
1. Use photoshop (or any other graphic editor) :-)
2. Use the multiple exposure feature on the K20D.
I am lazy so I will copy a page from the manual.
Keep in mind, the multiple exposure method will give you a ghosting effect (objects behind you will appear through you). If you really want a clean image, it is best to take two photos and Photoshop the rest.
02-17-2009, 12:43 AM   #3
I did that, with myself sitting in two different chairs. The problem is that I am see-through. How can i make myself 100% solid?
02-17-2009, 01:04 AM   #4
pentaxmz's Avatar
That is what I already told you.
The only way around that is to go with my first recommendation.
02-17-2009, 01:11 AM   #5
KungPOW's Avatar
A multiple exposure will always leave you looking see through.
I have done this with a film camera by locking the shutter open on bulb with a black card covering the lens. This is done on a tripod.
Have a friend hold the card, and you sit in chair one. Your friend moves the card aside exposing 1/2 the lens, and 1/2 of the sensor. Then youe assistant covers the lens.
You move to the other chair. Repeat the 1/2 exposure of the lens, and recover. release bulb setting.
Try this until you like the exposure you are getting. Something like a 2 sec exposure (per side)should do it.
02-17-2009, 01:16 AM   #6
pentaxmz's Avatar
QuoteOriginally posted by KungPOW Quote
Great idea!
I had forgotten about this trick, which was ideal back in the days before Photoshop.
02-17-2009, 01:22 AM   #7
Douglas_of_Sweden's Avatar
Cokin has a practical mask that covers half the lens which can then be moved to the other half with enough precision not to cause a black line or double exposed (too bright) line in the middle of the picture. This used to be the old way of doing this before ps. If the camera have double exposure possibilities you don't need to use b setting, just expose as normal, but twice, covering half the picture each time.
camera, dslr, exposure, photography
Multiple Exposures with the K-x jaieger Pentax DSLR Discussion 1 07-11-2010 02:27 AM
Multiple Exposures at a Local Creek Joe_M Post Your Photos! 3 03-12-2008 06:55 AM
help on double exposures danielleb3ar Pentax Film SLR Discussion 7 12-22-2007 05:31 AM
Multiple Exposures dawsonjm Pentax DSLR Discussion 11 10-09-2007 05:37 PM
more multiple exposures Donald Post Your Photos! 6 06-18-2007 10:24 PM
All times are GMT -7. The time now is 09:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
