02-17-2009, 10:40 AM   #1
LCD on K20D
Hi,
This may be a question asked a hundred times. If it is just send me an e-mail with the answer and don't tie up the forum. I have had a K10D for over a year, and just added a K20D. The LCDs on both cameras have always shown the remaining shots on the SD card. I did something to the K20D so that now it shows the ISO being used and I have to look in the viewfinder to see the exposures left. Is there a way to restore the LCD to where it was?
Thanks, Jim Weekes
02-17-2009, 11:19 AM   #2
This is a common question so am replying here. Watch the frames remaining number in either the viewfinder or the top LCD and then press the OK button on the back of the camera. It should change to the currently set ISO. The OK button is a toggle for this in many modes.
Jack
02-18-2009, 09:26 AM   #3
Jack,
Thank you. It didn't seem to work. I cannot get the remaining exposures to display in the LCD. When I hit OK a line appears below the ISO. I am in RAW mode, usually in P or AV.
Jim
02-18-2009, 09:42 AM   #4
AGW
Well that worked on my K200d.
And thank you for the tip. I must have completely missed that in the book.
Al
02-18-2009, 09:56 AM   #5
Presto's Avatar
In the custom menu, go to "dispay sensitivity". It should be "ON". Just turn it off. Your LCD should display the frames left again. If you want to see the ISO speed when you are in this mode, you just have to press the OK button. You can also change your ISO while holding the OK button by turning your fron e-dail. Hope this helps.
Presto
02-18-2009, 10:28 AM   #6
Bingo! I had "display sensitivity" ste to on for some odd reason. All is well. Thank you all.
Jim
02-18-2009, 11:24 AM   #7
Ah, yes. Forgot about the Display Sensitivity custom setting. Glad you go tit sorted.
02-18-2009, 11:29 AM   #8
QuoteOriginally posted by jymbo46 Quote
Hi,
Thanks, Jim Weekes
You changed your e-dial mode configure for your shooting mode. Go to menu-> custom setting-> e-dial in XX mode, depend on what mode you are on, just change the e-dial config, 1 is default. This should show back picture reaming. Even if ISO is shown, you can still press OK to show remaining pic
02-18-2009, 06:00 PM   #9
falconeye's Avatar
Yes, but...
Having ISO displayed instead of remaining images is a very nice option. The question then would be: How can I see the count of remaining images then?
Pressing OK doesn't help here.
But after every image taken, the count of remaining images is displayed for a second on the top LCD before reverting back to ISO. Works for me.
camera, dslr, k20d, lcd, photography
K20d LCD protector madisonphotogrl Pentax Camera and Field Accessories 16 05-28-2009 04:53 AM
K20d + lcd tv soccerjoe5 Pentax DSLR Discussion 23 03-24-2009 10:38 PM
How do I connect a K20D to an LCD? soccerjoe5 Pentax DSLR Discussion 14 03-14-2009 10:25 AM
Anybody use this LCD protector for K20D? HermanLee Pentax Camera and Field Accessories 16 02-23-2009 10:30 AM
LCD View K20D gordon_l34 Pentax DSLR Discussion 3 12-25-2008 05:03 PM
All times are GMT -7. The time now is 11:27 PM. | See also: NikonForums.com, part of our network of photo forums!
