02-17-2009, 05:48 PM   #1
White Balance 'filters'
i have seen in the photography stores these items that look like a filter that screw onto the filter threads of your lens. When i asked they said it was to assist in setting your white balance. Has anyone ever bought one of these?? If so How well did it work???
Thanks in advance, I hope someone knows something!
02-17-2009, 06:01 PM   #2
I almost fainted the last time I saw the prices of those "white balance filters" or "white balance lens caps."
I shoot RAW, and adjust the white balance in the comfort of my home.
If I really need to do a "white balance" when shooting, I use an 18% gray card (I have several since the film days) or use a white foam cup.
02-17-2009, 09:12 PM   #3
OK I am new to digital (K200D). I understand White Balance all right but it sounds like you are equating 18% gray to the bright white of a foam cup. Where did I misundersand???? Not a comment, a real question that might sound too basic if you know the answer but I don't.
Thanks,
TomK
02-17-2009, 09:32 PM   #4
QuoteOriginally posted by TomK Quote
Thanks,
TomK
One has to understand that it is all about the light. White balance changes due to the "temperature" of the light. This is why I do not understand the filter things. Sunlight has a different temp than incandescent light which has not much to do with flash. I prefer shooting without flash although it is easier with a digital camera. For instance in my living room, I mostly have compact florescent lights but they are not all the same type or brand so depending on what is turned on I have to adjust the white balance. So it is nat actually about what is white and what is not white, it is about how intense and bright the light, or in the correct terms the temp of the light. Hope that helps about the 18% gray and the white cup. No one has helped me yet understand these white balance filter things.
02-17-2009, 09:47 PM   #5
SpecialK's Avatar
White balance is a color thing, not an exposure thing. Black, white and gray are all the same "color" to a camera. If there is no tinge of color in the gray (as with a true "gray card"), it works fine for white balance. So does a white coffee filter squished between UV filters (I'm told).
I'm with SOldBear and shoot RAW, so WB and many other variables are not an issue during the shoot. But I only adjust WB later if it is really noticeably (like blueish snow).
02-17-2009, 10:14 PM   #6
alohadave's Avatar
QuoteOriginally posted by kacansas03 Quote
A coffee filter is nearly free if you already drink coffee. Translucent Pringles lids or coffee can lids will work too.
The reason it works is because the camera defaults to the entire frame for WB adjustments. By diffusing the entire frame, you are blending the light together so the camera can determine the overall color balance.
Personally, I just set the WB size to the spot focus area and take a reading off reflected light on something white. I fine tune it if needed.
02-17-2009, 11:32 PM   #7
Inexpensive route
If you don't want to look too cheap... https://www.amazon.com/s/ref=nb_ss_?url=search-alias%3Daps&field-keywords=ge...lance+lens+cap
02-18-2009, 02:36 AM   #8
abraham_love's Avatar
They are only about £3 on eBAy from China. They work well and they are lens caps too. Win/win!
52mm White Balance Lens Cap/Grey Card Lens Filter AX02 on eBay, also, Lens Caps, Camera Lenses, Photography (end time 24-Feb-09 17:11:34 GMT)
02-18-2009, 07:21 AM   #9
Hold a coffee filter over the lens and point it at the light source when you preset the WB.
02-18-2009, 07:36 AM   #10
Coffee filter? Bah! Check this out:
CBL Lens Full Color Balance and White Balance Control System. Say goodbye to color correcting.
The Grey Reverse Side is formulated from a secret combination of thirteen different materials which have been tested to produce the most consistent color balance and is best suited to studioflash photography and direct sunlight.
A coffee filter is only made of one material! Paper! This one has Thirteen!!!! and only costs ~$100USD
/end sarcasm
I guess for a pro who may need to adjust WB for mixed light sources this might be something to have. But for a hobbist like myself shooting in RAW and adjusting later is so much more economical.
02-18-2009, 08:02 AM   #11
Jodokast96's Avatar
Want to know what's really messed up? In every single shot on that site, I prefer the ones that weren't "corrected".
02-18-2009, 09:21 AM   #12
get a whibal...they're individually checked w/ a spectrophotometer before being shipped...
02-18-2009, 11:34 AM   #13
Shooting RAW and adjusting later has been exactly what I have been doing with my Apple iMac's iPhoto. I haven't evens pent the money on their program for handling digital images. IPhoto works fine but I think I will have to break down and make sure the colors on the monitor are correct, make sure I know what I am doing with the camera's white balance, and lastly get the better imaging software. maybe I will have to ask about that next???? MrApollinax, did you see my call to MN Pentax users?? You would be a great addition to our group.
02-18-2009, 03:04 PM   #14
And not 13 any old "materials"... they are "formulated from a secret combination"!!
It's SECRET! That makes it instantly scientifically awesomer. Seriously.
Ha! I was thinking exactly the same thing.
Sometimes a "color cast" actually ends up giving the photo a "feel" that is actually
closer to what it actually like in real life. A "perfect" WB sometimes looks, to
me, a bit sterile.
Of course, that is just another argument for shooting in RAW and making that
aesthetic call after the fact.
[kurt]
02-18-2009, 03:24 PM   #15
I think I am going to have to post the "Blue Christmas Tree" photo that was one of the first I took with my K100D. The tree was decorated in all blue plus had 6 strings of blue LED lights on it. I thought there was something wrong with the camera at first then realized that the corner of the living room the tree was in really did look very, very blue. The photos are really neat because almost everything is blue or almost black looking which is how it looked with all the other lights off. Then my wife changed it so there were all kinds of colors of decorations and a lot less blue lights. That is how I started learning white balance.
balance, camera, dslr, filter, photography
White balance fekish Troubleshooting and Beginner Help 24 10-06-2010 06:31 PM
White Balance GordZ Pentax DSLR Discussion 2 01-19-2010 01:08 PM
White Balance JCSullivan Photographic Technique 18 08-31-2008 11:59 AM
Help with White Balance MSM Pentax DSLR Discussion 18 01-09-2008 12:12 AM
Auto white balance vs. daylight balance outdoors. fevbusch Pentax DSLR Discussion 7 02-18-2007 03:04 PM
All times are GMT -7. The time now is 07:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
