Quote: Can someone please correct my misunderstanding of this function and tell me how to do it correctly? I heard this is another way to increase the dynamic range of a photo...
Thanks!
Ken
I can see why you are having a problem with this function. I read the K20 owner's manual (p103) & then tried to get a multi-exposure myself. The directions in the manual leave a lot to be desired if you ask me. Firstly, you do need to use a tripod, and perhaps a remote, if you are hoping to get a better exposed sunrise or sunset. Otherwise, you will just have blurring because the frames will not line up.
Quote: Special K:If you want some HDR effect, I believe you need to change the exposure between shots. And a tripod would be useful to get the same framing
According to p 103 of the manual, when auto EV is on,
the exposure is adjusted automatically according to the number of shots..
Quote: Zebooka You would never get HDR effect with multi exposure.
They are different things
I think you are correct, that HDR is different from Multiple Exposure, however, the multiple exposure feature must, to some degree, simulate the HDR effect. With ME you can take up to 9 shots, all at different exposures, and piggy back. Of course this will not be as dramatic an effect as HDR, but surely it will put some pop into images.
The main difference from HDR would be the HDR is heavily reliant upon software and post-processing. I have not yet used the ME function, but it must have been the tool which provided the impetus for HDR.
Javaslinger: Setup a tripod and shoot somewhere between 2 and 9 images with precisely the same framing. Use a remote to trigger the camera if possible. Also, leave the auto-EV on and let it adjust the exposures.
After you have shot the number of exposures needed for the ME, then look at the finished image. I believe, once you go back into the menu, you automatically shut off the ME feature. So, you first need to select how many shots you will expose for, and then take them. They do not have to be one right after another, apparently, though I can see why your reasoning would intuit that.
When you are done, please post here for us. I'd love to see just what this feature is capable of doing. Thanks and Best!
