Originally posted by Reportage i was wondering if its okay to mess with the camera firmware to find the rules for the strobing effect and instead set to Always On.
Is it OK? You mean, you have the technical expertise to reverse engineer the firmware yourself and make the change? I'm sure it would void the warranty, but if you've got the programming chops to pull it off, I can't Pentax sending out the lawyers to stop you. Or are you asking something different?
As it is, while you could indeed pop up the flash, use it to focus, then close it before taking the picture, I figure that takes about 10 times longer than simply focusing manually.
