02-18-2009, 08:59 PM   #1
jpzk's Avatar
K20D Built-in Flash ... questions
Hello everyone.
I am starting to use the K20D built-in flash for backlit situations such as a subject with a setting sun behind, or a harsh snowy (white) scene into which a human subject is and with a low, very harsh sun behind.
I wanted to know what would the settings be? I.E.: Slow or Normal, what max shutter speed used if I am in Av or TAv mode(s) ... that sort of thing.
Also: is there an already "calculated" distance scale available somewhere so I won't have to do all the mathematics myself, according to the lighting situation and type of lens used?
Any helpon the matter would be greatly appreciated!
Thanks.
JP
02-18-2009, 09:11 PM   #2
Das Boot's Avatar
Your best bet would be to stop the lens down until the shutter speed is within the flash sync speed of 1/180 and use it as normal. You may have to adjust the exp. comp. of the flash to get a "natural" look. If this is not an option, ie fast moving subject or not enough in camera flash power, your best bet would be to get a shoe mount flash with a high speed sync option and not worry about the above and just shoot normal.
built-in, camera, dslr, flash, k20d, photography, subject, sun
In what situation can you use the external flash that the built in flash couldnt? rustynail925 Flashes, Lighting, and Studio 25 01-13-2010 01:26 PM
Need help with the K20D built-in flash tttomato Pentax DSLR Discussion 3 12-23-2009 01:06 PM
flash guide updated for k-7 built-in flash mattdm Pentax News and Rumors 4 05-26-2009 06:02 PM
best way to use built in flash? furby Pentax DSLR Discussion 8 10-01-2008 01:32 PM
wireless flash using built in flash k200d dtra Flashes, Lighting, and Studio 3 04-04-2008 12:34 AM
All times are GMT -7. The time now is 03:59 PM. | See also: NikonForums.com, part of our network of photo forums!
