Originally posted by shuttervox First off, am I right to assume that the viewfinders of the K200d and the K-m/K2000
are the same pentamirror?
Yes.
Quote: I was trying out a Nikon D40 in the store the other day, and I found the viewfinder
to be quite "tunnelly". The D40 has a magnification factor of .80, where as the
K200d and K2000 are .85
I haven't found a Pentax in-store yet- Is this really enough to make a difference?
Yes.
Quote: I suppose I could get used to the small viewfinder, but it felt kind of claustrophobic.
I think so too.
Quote: The K20d Pentaprisim is .95, and I assume this is closer to what I am used to on
film SLRs?
Nope. You have to divide 0.95 by 1.5 as the same image at the same focal is cropped. So, if you have to compare for the same Field/Angle of View, the true magnification is 0.63X only (by far less than what you can get with a film SLR, typically around 0.8X for Pentax SLRs)
