02-21-2009, 06:35 PM   #1
rparmar's Avatar
Need help: how to set manual mode e-dials
So far I'm liking my K20D, but I've found an annoyance.
I like direct control over ISO, so I've used the custom settings to set the rear e-dial to ISO and the front dial to aperture. I should state that I really only ever use aperture-priority and manual settings. Old habits die hard!
In order to change the settings for manual mode I use "24. e-dial in TAv & M". But for some reason there are only two settings. One allows the front dial to control shutter speed and the back aperture. The other setting is the other way around. Neither setting lets me control ISO. Why is this missing? And why would I want a dial to control shutter speed when you cannot do this with a manual lens in manual mode? The dial becomes useless. Isn't this rather dumb?
I'm hoping that I've missed something obvious. Otherwise the controls are letting me down precisely when I most need to customise them.
02-21-2009, 06:43 PM   #2
Jodokast96's Avatar
Pressing the OK button and either a) turning the front dial; or b) turning the dial controlling aperture will let you change the ISO. I'm just not sure which it is as I have mine set with the front dial controlling aperture.
02-21-2009, 07:04 PM   #3
Mike Cash's Avatar
QuoteOriginally posted by rparmar Quote
Why can you not control shutter speed with a manual lens in manual mode? Perhaps you meant to say that the green button will set the shutter speed for you in manual mode. That is true, but it doesn't mean that's the only way to set the shutter speed with a manual lens in manual mode.
Anyway, you're bumping into why they call this mount "crippled". If you want to change ISO in M mode, you're going to have to go with the awkward OK button plus front dial combination.
With M42 lenses I use Av mode, the camera does the shutter speed for me, and I have the rear dial set up for ISO and can change quite easily. Yet another reason M42s are easier to use on modern Pentax DSLR bodies than the M series of lenses are.
02-21-2009, 07:47 PM   #4
rparmar's Avatar
QuoteOriginally posted by Mike Cash Quote
Sorry, typo. I meant to say I could not control aperture with the dial, since this is being controlled from the lens itself. Thus having a dial assigned to aperture in manual mode makes no sense for these lenses. I had not tried the K20D with an M42 so did not realise the greater freedom.
Darn. I do in fact find that awkward. In fact I find the back e-dial awkward in any case. But I'm thinking it is the software that's letting me down, not the mount. Surely I should be able to control ISO on the body with an e-dial no matter what lens I was using?
Looks like an oversight in the firmware.
02-21-2009, 10:32 PM   #5
Holding in the OK button while turning the front e-dial changes the ISO for me in M mode.
02-21-2009, 11:36 PM   #6
creampuff's Avatar
rparmar, I suggest you read this:
PENTAX digiich
PENTAX digiich
Most people coming from a film background would predetermine the shooting ISO first and use the aperture and shutter speed solely as exposure variables in manual mode. Alternatively you could use TAv mode and allow the camera to vary ISO.
02-22-2009, 10:38 AM   #7
rparmar's Avatar
QuoteOriginally posted by creampuff Quote
PENTAX digiich
This is an article on Shutter & Aperture-Priority (TAv) mode. When I use this with a manual lens (with the front dial set to shutter and the back to aperture) this is what I get:
front dial: nothing
back dial: sets ISO
green button: nothing
The camera ignores the aperture ring on the lens.
I assume this is not correct usage.
I am unsure as to what you are suggesting.
02-22-2009, 10:41 AM   #8
rparmar's Avatar
QuoteOriginally posted by jbinpg Quote
True. But I was trying to avoid using the OK button. In every other mode I can.
Apparently I have found a limitation of the firmware. Annoyingly, this covers a very frequent usage scenario for me.
aperture, camera, control, dslr, e-dial, front, iso, mode, photography, settings, shutter
K-x: Can Aperture be set in Green Mode? Edmund Troubleshooting and Beginner Help 4 06-15-2010 08:21 AM
How to set K20D + 2 AF540 in Manual & wireless mode? HermanLee Flashes, Lighting, and Studio 4 10-21-2009 09:11 AM
What drive mode do you set on default? Luciferase Photographic Technique 32 04-05-2009 07:38 AM
Cannot set to A mode rightaway Andi Lo Pentax Camera and Field Accessories 5 01-13-2009 01:52 AM
K100ds and full manual mode w/manual lens dwhopson Pentax DSLR Discussion 10 11-06-2008 10:37 PM
All times are GMT -7. The time now is 07:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
