02-22-2009, 08:51 AM   #1
willyflyboy's Avatar
Ver 1.30
I was going to update my firmware on my K10 from 1.10 to 1.30. Will I see a BIG difference besides ability use the the remote software.
02-22-2009, 09:18 AM   #2
StarDust's Avatar
PENTAX K10D FIRMWARE UPDATE VERSION 1.30
VERSION HISTORY
Version 1.30
* Added compatibility with the supersonic motor drive of Pentax SDM lenses.
Version 1.20
* Added the required programming for compatability with the Pentax Remote Assistant 3 software.
Version 1.11
* Improved multiple exposure function when shooting in RAW.
* Corrected an issue with luminescence control and trailing shutter curtain sync when using the built-in flash.
Version 1.10 (CLICK HERE for a PDF containing more details on v1.10 changes):
* Using the camera's built-in flash, you can now wirelessly control external Pentax flashes. Previously, you needed an accessory flash mounted in your camera's hot shoe, but now the built-in flash can act as a control flash.
* In autofocus select mode, you can program the AF button to instantly return to the center autofocus point.
* In Tv or Av mode, you can now program the second e-dial to adjust your ISO setting.
* In any exposure mode except Sv and TAv, you can change your ISO setting with the front e-dial while pressing the OK button. The camera will display your ISO in the viewfinder and on the top LCD panel as you adjust your setting.
* In TAv mode, you can program the green button to return to the camera's program line. Previously this functionality was only available in M mode.
* You now have additional options for programming your e-dials in P mode.
* Pressing the green button while adjusting flash exposure compensation will now return you to the default value.
* Corrected an issue in some rare cases where a long exposure might produce a vertical stripe.
* Corrected an issue where the battery charge indicator would sometimes show empty in bulb exposure mode.
02-22-2009, 06:58 PM   #3
QuoteOriginally posted by willyflyboy Quote
But the 1.30 firmware won't let you use the debug mode for AF adjustments, which quite some of the K10D users found it to be a crucial "feature".
For more detailed and related info, you can read my old articles below:-
RiceHigh's Pentax Blog: Secret Firmware Menu of the K10D (V1.10)
RiceHigh's Pentax Blog: How to Get Back to an Older Version of the Firmware?
RiceHigh's Pentax Blog: K10D Firmware 1.3 Debug Mode Unleashed
02-23-2009, 03:47 AM   #4
Zebooka's Avatar
It will let you, but only with additional program, not by key-combo.
02-23-2009, 06:27 AM   #5
RiceHigh: Thans for the links. It is always a good thing to know how to go back after an upgrade just in case it did not work or not happy with it.
02-23-2009, 06:33 AM   #6
QuoteOriginally posted by jjdgti Quote
You're welcome! :-)
camera, dslr, photography
K100D ver 1.02 Firmware Update Frosty Pentax DSLR Discussion 6 04-29-2010 12:27 AM
Problem upgrading my K-x to firmware ver. 1.01 Tim_R Pentax DSLR Discussion 7 03-09-2010 05:26 AM
K20D Firmware Ver - Pentax Web Site Ver? ChipB Pentax DSLR Discussion 2 02-23-2010 04:14 PM
GX10 ver. 1.0 samples KAFman Pentax DSLR Discussion 1 11-13-2006 03:48 PM
All times are GMT -7. The time now is 09:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
