02-22-2009, 11:29 PM   #16
jct us101's Avatar
Along with costing so much more...
02-22-2009, 11:33 PM   #17
6M is very little..
QuoteOriginally posted by jct us101 Quote
6 megapixels is plenty.
Not really. Let's have some maths..
My Samsung thermal photo printer has a native resolution of 300 dpi, it is designed to print 4R photos. Suppose it can print in larger size, with a 6MP source picture, how large *should* it be printed?
6MP = 3000 x 2000 (but not true resolution owing to the Bayler's artifacts and other imperfection like jpeg loss and optical aberrations etc.)
Even assuming it has the "perfect" resolution in 3000 x 2000, you can get only 10" x 6.7" print at most. In reality, a 14.6MP K20D could produce *optimal* resolution of around 2,400 dots per picture height in real measurements (by various reviewers) which just means that at a standard 300 dpi printing resolution, it should not print more than 8" for a picture before "inadequacy" in resolution can be seen! So, if it is just 6M..?
02-22-2009, 11:35 PM   #18
jct us101's Avatar
RiceHigh, I have a 6 megapixel camera and it's plenty for me. So please tell me why I'm wrong.
02-22-2009, 11:35 PM   #19
Venturi's Avatar
As usual, Rice, you are completely correct in every respect. All of these photos are just dreadful. I'm sure the photographers that made them are filled with shame and embarrassment for their "substandard" equipment...
02-22-2009, 11:42 PM   #20
Not Correct..
But the problem is that technologies are always advancing. The K100D was marketed in 2006 and the K-m is marketed in 2009.
Its true if Pentax is to make a 6MP DSLR again in 2009, it will be with super low noise. But this will not happen as no one will make a 6MP DSLR again in 2009 and no one will probably buy it even they make one.
A good example is that the Canon 5D MkII is of around 21MP whilst the 5D MkI is of about 13MP but the MkII does have about 1 stop advantage in terms of noise level between different ISO speeds. The Nikon D700 is even better than the 5D MkII, since it has only about 12MPs.
Not until we compare stuff with the same technologies, it could not be meaningful..
QuoteOriginally posted by RiceHigh Quote
6MP is just too little by today's minimum standard, frankly - even most P&S DCs start from 10MP.
And that's why they are noisier. You *are* aware that more pixels means more noise for the same sensor size & technology, aren't you? That's not to say the K200D is worse than the K100D - it isn't, really, by the time you view the images the same size. But it's also true that very few high pixel count camera produce cleaner images than the 6MP DSLR's.
02-22-2009, 11:43 PM   #21
Explained above already.
02-22-2009, 11:45 PM   #22
QuoteOriginally posted by Venturi Quote
Hey, pls don't take any of my technical views above as anything personal. Its just an open discussion on the technical stuff.
In fact, for all the excellent 6MP pictures you've shown, they can be much better and be printed in larger if they had more pixel counts - no conflict of any but only advantages here!
02-23-2009, 12:23 AM   #23
Andi Lo's Avatar
OP, whether or not you think Ricehigh is right or not that K-M would be a better choice over the K100D (which I don't, due to cost and features comparison), please take a look at the link that Venturi posted and decide for yourself K100D has been more of a camera that I can handle after one year of using it, and if you're just starting it will probably be the same for you. In fact this thread and the PPG link has reminded me not to lust after newer camera bodies yet since most equipments are probably better tools than I am a photographer. I got feelings of deja vu as well since pictures from the K100d are what made me decide on pentax a year ago.
Cheers,
02-23-2009, 12:43 AM   #24
QuoteOriginally posted by Andi Lo Quote
Cheers,
Andi, I generally agree with what you (and others) are trying to point out.
However, I would think more that a better tool will always be a better tool, the same photographer with a better tool will always produce better works!
A better tool will always help you to get more photo opportunities and makes better shots. In this case, the K-m has better and improved Auto White Balance, faster Auto Focus and better metering and so on just undoubtedly makes it a better tool!
02-23-2009, 12:53 AM   #25
Jasvox's Avatar
I'd go with the KM, simply based on newer technology and the size..very packable. Either camera body is fine and either one should serve you well.
Jason
02-23-2009, 01:18 AM   #26
jct us101's Avatar
RiceHigh, I've had it with you. You're simply a joke. Just because something might be better now that makes what was avaliable before obsolete in terms of quality, that doesn't mean that you don't have a valid reason for using it. Why do people still use Kodak Brownies, or Polaroids? You can buy a digital camera that gives you nearly perfect photos, but in the process you've taken the important part entirely out of it, and that's the technique. What's the point of taking a 10mp photo snapshot that you can simply crop everything out of when you can have so much better of a photo with 6mp that you don't have to crop, but along with your technique included. I just realized none of this made any sense, but I don't really care.
02-23-2009, 02:26 AM   #27
In fact, the resolution difference can be clearly seen on a full screen (not full sized) picture displayed on a 19" monitor or larger.
So on your 19" monitor (probably with a resolution of 1280x1024 = 1.3 megapixels) you can somehow see a "clear" difference between a full screen 6 mp image and 10 a mp one? Interesting... Please PM me if interested in selling me a bag of whatever it is you're smoking.
02-23-2009, 02:31 AM   #28
So, what's the problem of a newer and better camera and the conflicts arising from using such a camera in making good photos?
6M is too little in pixels by today's standard - especially when all the new buyers are having the *choice*. I have shown the maths already. If you don't agree, don't go it personal, just show your viewpoints or arguments, if any.
Unless you can learn how to respect others in your reply without attacking others personally, I shall not respond to your post in this thread further.
02-23-2009, 02:35 AM   #29
QuoteOriginally posted by Erik Quote
Yes, a source that is with much higher resolution and contain more picture information will always be better even it is downsampled - universal truth here. (not only for digital pictures but for all digital media and formats!)
Just believe it or not! (but I think it should not be too difficult for anyone to verify the truth..)
02-23-2009, 02:37 AM   #30
Yes, a source that is with much higher resolution and contain more picture information will always be better even it is downsampled - universal truth here (not only for digital pictures but for all digital media and formats!)
To a degree, but not to THAT degree. Now, if you started talking about resampling 10MP to 6MP and then comparing that to a native 6MP image, you would be making more sense.
camera, dslr, pentax, photography
New Pentax User Whitepines Welcomes and Introductions 2 09-06-2010 11:42 AM
New Pentax User (almost) Markos007 Welcomes and Introductions 4 06-30-2010 10:14 AM
new pentax user tguy2006 Troubleshooting and Beginner Help 2 06-13-2010 09:28 PM
New Pentax user suga Welcomes and Introductions 4 08-11-2009 02:56 AM
New pentax user from NJ!!! Senseriffic Welcomes and Introductions 3 02-02-2009 08:54 PM
All times are GMT -7. The time now is 08:25 PM. | See also: NikonForums.com, part of our network of photo forums!
