02-25-2009, 10:00 AM   #1
Pentax K100D Fireware update problems
I'm hoping someone can help me with this I've tried everything I can think of...
I've been trying to update my Pentax K100d firmware from v 1.00 to v 1.02 using the update on the Pentax page.
Pentax Canada - K100D
The instructions seem simple enough...I insert a new blank 8gb SDHC card into my card reader, put the .BIN file on the card, eject, insert it into the camera and turn the camera on while holding down the Menu button.
Instead of the 'Update Firmware? Yes/No' option your supposed to get my camera pauses for about 10 seconds and then starts up and displays 'Firmware V 1.00' and then says 'Memory card error'
I've tried using two different 8gb SDHC cards and tried it on my iMac and a PC and still no luck?
Can anyone help?
P.S. I'm a bit confused by the update itself, if says that the firmware update adds SDHC compatibility, but then says I need to put the update on an 8gb card (which would have to be SDHC) so then how is the camera supposed to read it?
02-25-2009, 10:17 AM   #2
The instructions say 8 MEGABYTES (or more!) for the SD card
So yeah using an 8GB SDHC won't work
I think I still have some old 128MB cards sitting around somewhere
02-25-2009, 10:23 AM   #3
chalion's Avatar
Use SD Card, NOT SDHC
You'll need to use a smaller capacity SD card. These typically are 4 GB or less. You can pick a 1 or 2 GB at any retail store that carries any type of media (blank CDs, DVD, VCR tapes, etc.). Using a SDHC card will give an error because your camera doesn't recognise it.
QuoteOriginally posted by egordon99 Quote
02-25-2009, 10:31 AM   #4
1) K100D with firmware 1.00 does not support SDHC cards. It's an 1.02 software that supports them so you need SD card (2 gb or less)
2) Check you have K100D, not K100D super. K100D Super is different camera.
02-25-2009, 11:36 AM   #5
Wow, that's embarrasing
Thanks for the help!
Yes of course it's 4.2MB not GB, Pentax's page threw me off when they said an SD card with minimum 8MB. I don't even think in MB anymore!
09-23-2010, 05:44 PM   #6
rochmind
Guest
I've got the k100d super with v1.00 firmware.. does it mean the v1.02 firmware does not apply to this model?
09-23-2010, 05:49 PM   #7
alohadave's Avatar
QuoteOriginally posted by rochmind Quote
The Super already had SDHC support built in. No need for a firmware updated.
09-26-2010, 07:36 PM   #8
rochmind
Guest
i still use a 2gb card.. may get a sdhc to check it
camera, card, dslr, firmware, k100d, pentax, photography, sdhc, update
Pentax K100D Problems pnind Pentax DSLR Discussion 3 06-10-2010 09:24 AM
k100d super, lens problems (m42 to pentax K) M0ppeN Troubleshooting and Beginner Help 3 03-19-2009 02:29 PM
How To: Firmware update on K100D ron305 Pentax DSLR Discussion 2 05-27-2008 06:15 PM
Lightroom v1.4 Update Problems with PEF mithrandir Digital Processing, Software, and Printing 4 03-17-2008 07:03 AM
Problems with Pentax-A lens on K100D xs400 Pentax SLR Lens Discussion 5 10-31-2007 09:53 PM
All times are GMT -7. The time now is 01:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
