02-25-2009, 01:52 PM   #1
using an aperture ring lens on the K100D Super
Hi,
one of the main reasons that i bought my k100d super was that i read i could use my old manual pentax lenses with an aperture ring on my new digital camera. I often perfer to switch everything to manual, and besides I'd hate to rebuy lenses that i more or less already have, only they're not auto. I have made sure that the option for using an aperture ring it selected to 'yes' in the custom settings menu, but when i put the old lens on the camera and set my metering mode to manual i don't get any meter reading sugesting a shutter speed for the aperture that i've chosen. this is when i use a lens without the A setting. i have successfully used an old lens that has an A setting as long as the A is selected and not an individual f stop. but my 50 mm lens is the one i want to use because it will open up to f 1.4, but it doesn't have an A setting.
do i have to buy myself a handheld light meter in order to use this lens?
02-25-2009, 02:01 PM   #2
Lowell Goudge's Avatar
set the function in the menu to Use Apature Ring
then you can meter by selecting DOF preview in manual mode, shoot wide open (only) in Av mode, or set the shutter speed to match the selected apature (manual mode) by pressing AE lock
02-25-2009, 02:05 PM   #3
Jodokast96's Avatar
Set the Preview Method in the menu to Optical. Then hold the preview lever (OFF/ON/Preview). In the viewfinder, on the far right, it will tell you how many stops over or under your shutter will expose.
**EDIT** What Lowell said. The K100D is my daughters and I didn't know the AE-L button functioned like the Green Button on the higher ends.
02-25-2009, 02:10 PM   #4
Thank you so much. That makes complete sense!
aperture, camera, dslr, k100d, lens, lenses, meter, photography
Sears lens with PK on aperture ring (K mount??) jqjones Pentax SLR Lens Discussion 3 02-16-2010 10:20 PM
For Sale - Sold: Phoenix 100-500mm f/5.6-8.0 KA auto-aperture super-zoom lens wallyb Sold Items 8 09-10-2009 07:00 PM
Use of Aperture-Ring 43mm/1.9 -> no aperture data Deimo Pentax SLR Lens Discussion 7 06-24-2009 03:25 PM
Using aperture ring? audiobomber Pentax DSLR Discussion 6 10-07-2008 02:31 PM
All times are GMT -7. The time now is 07:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
