The K100d Super has impressed me aswell. And it does good looking higher Iso.
Originally posted by soccerjoe5 Why do you prefer it over the Pentax one, does it have bigger magnification ?
Originally posted by ghost You just blew my mind with that knowledge
sooooo you are saying 200 is 100, 300 is 200 and so on? Aren't all ISOs other than the base pushed?
It doesn't really matter but I'm an inquiring mind (great show btw)
By starting at a higher Iso base, you can expand further into high Iso territory. The D700 base is Iso 200, makes for extraordinary high Iso.
Originally posted by Erik 200-1600 is the true ISO range of the sensor. This means that in that range, the analog signal is amplified by the sensor electronics before it reaches the firmware. The difference in 3200 is that the sensor is set to amplify the signal to 1600, and then the firmware essentially just doubles all the bit values, i.e. a digital operation. Doubling the digital values of 1600 picture data means there is no more real information in a 3200 file than in a 1600 file. This is also why Nikon cameras call the highest ISOs silly things like Hi1 and Hi2; to further hammer in the point that these are just tricks pulled by the camera.
Thanks, I didn't know about the Hi1, etc.
Originally posted by PentHassyKon Thanks, I could use a good charger. Does it take longer, with many batteries in ?
Edit : found something on the Maha charger
http://www.steves-digicams.com/maha_c204f.html
