03-02-2009, 11:18 AM   #31
Re: Data for user score
Hi,
the data is found under each camera on the DP Review site. It is based on user feedback of each camera. Please find the links to the scoring for each camera.
Pentax K20D:
Owners Opinions: Pentax K20D: Digital Photography Review
Pentax K10D:
Owners Opinions: Pentax K10D: Digital Photography Review
Canon 50D:
Owners Opinions: Canon EOS 50D: Digital Photography Review
Canon 40D:
Owners Opinions: Canon EOS 40D: Digital Photography Review
Nikon D80:
Owners Opinions: Nikon D80: Digital Photography Review
Nikon D300:
Owners Opinions: Nikon D300: Digital Photography Review
You can also find score for all other DSLRs, but so far I have not found any that scores higher in user scoring than K10D and K20D.
Best regards,
Haakan
03-02-2009, 08:22 PM   #32
Getting new lenses tomorrow
Hi all:
I should be getting the new 16-50 lens and see how it compares with the one I have now that does not focus well. The mail order vendor is allowing me to compare them and has been excellent about the returns I have made.
I also will be getting the 50-135, too. I hope that is a good copy. I am a bit nervous. I know there has been a lot of talk about the quality control issues of the 16-50 lens. Is this just a Pentax problem or do Canon and Nikon have the same level of returns? I know no company can mass produce lenses without any issues, but this seems problematic--or is it just that I am annoyed it happened to me?
Also, can you let me know how I can upload a picture with the EXIF information attached?
Thanx again. I very much appreciate all of your help.
03-02-2009, 08:48 PM   #33
Hi lawjbm
Re your query;
Check out this link to a previous post of mine, which contains a number of useful links:
https://www.pentaxforums.com/forums/117194-post9.html
If I recall correctly, unless you specifically strip-out/remove the EXIF data with some appropriate software before uploading your image(s), I believe the EXIF data should remain wholly intact for others to view it, using any of the software mentioned in the links I've provided.
Best regards
Richard
03-02-2009, 08:49 PM   #34
QuoteOriginally posted by lawjbm Quote
Look on a Canon forum for complaints about their 24-70L (yes an L series lens). It sounds like QC is as bad as Tamron's...people buy 4 copies to get one good one sometimes
For EXIF, I think you have to link to it...smugmug and zenfolio keep exif info...
03-02-2009, 09:32 PM   #35
"have a few dozen pictures from my living room"
go to search and type in front focus and tungsten. then adjust your lens in the custom menus whenever you shoot in tungsten.
03-02-2009, 11:11 PM   #36
iceemn360's Avatar
I think the more and more I use this lens the more i Love it!
03-03-2009, 11:04 AM   #37
Soft Images with 16-50
Some of the pictures in my house were made under tungsten lights, but many were made under fluorescent lights. Also, many pictures were taken outside on a sunny day and also a cloudy day.
I really put the lens through its paces. I tried to be realistic and not as anal as it sounds. The lens simply would not focus evenly. Pictures of my children were focused in the center and the left, but not on the right. Other pcitures were "clearish" in the center, the right, but blurry on the left. I used focal lenghths that should have produced evenly focused images (taking into account the lens is a f/2.8 lens).
I do hope the next one works. I will look up the tungsten focus thread, but I really do not think that was it. Thank you, though.
Gregg
03-03-2009, 12:47 PM   #38
Gregg...it sounds like you had a lens w/ a decentering defect (if you post an example, we can confirm).
Take a look at this thread and my post in it (the guy in the PFD):
Testing the Sigma 17-70 - Pentax Lenses - Digital SLR Cameras - Steves-digicams.com Forums
That was shot at f/8 IIRC.
03-03-2009, 11:50 PM   #39
Jewelltrail's Avatar
julianactive
Jewell,
Compare your RAW converted JPEGS from Faststone to just a JPEG from the same camera. See if you notice a difference.
Julian, thanks for the suggestion. I will do a quick test, geared specifically at this. Thanks.
03-04-2009, 01:32 PM   #40
New Lenses
I received the new 16-50 and the 50-135 lenses. They certainly feel different than the 16-50 that I have now (which actually is the second 16-50; I had returned a first k20d along with a 16-50 lens due to possible shipping damage).
The new lenses feel like they actually are snapping into focus. I hope I am not deluding myself and thinking this is what I am seeing. There definitely seems to be a diference in focusing. Both of the new lenses behave this way. Focusing is a tad bit slower, but seems more accurate.
My informal testing shows the lenses to be much better. In both there still seems to be some right or left edge softness at 2.8 or 3.5, but only if you are looking for it. At 4 or 5.6 images snap into focus. I assume this is normal?
I will do some more testing during the week and will take the camera outside on a tripod on Saturday.
One thing I did not account for is that the 50-135 is a heavy lens and hand holding it while testing may not be the most accurate way to do things. Even with SR on the onboard flash pictures inside have relatively slow shutter speeds.
Assuming I keep everything—and I think I will, the camera feels great and is becoming more intuitive to use the more pictures I take—I plan on getting the 540flash.
Does anyone know how fast a shutter speed I can use with the 540 for indoor flash pictures: casual family an friend shots?
Thanx so much.
Gregg
03-04-2009, 02:09 PM   #41
rfortson's Avatar
Thanx so much.
Gregg
Max shutter speed with flash (without going into high speed synch) is 1/180s on the AF360. Never played around with HSS, though.
03-04-2009, 02:33 PM   #42
Gregg: go do that fan exercise I posted earlier...you shouldn't be asking this question if you did...
03-04-2009, 03:27 PM   #43
What fan test?
Kenyee:
I apologize. What fan test are you referring to? I looked over the prior posts and did not see a fan test. Is it posted at the link you put up? I reviewed the link and do not remember seeing it.
Thanx so much.
Gregg
03-04-2009, 07:08 PM   #44
Gregg:
Enable your flash, set your shutter speed to 1/30sec and take a picture of a ceiling fan, house fan, etc. This should work even w/ the popup flash. The "strobe" effect of a flash will freeze motion...
03-07-2009, 04:15 AM   #45
had similar problems with my 50-135 lens, had a hard time finding focus, and the pictures was not "sharp". Tryed focus charts etc but in focus was blurry. Sent it to service 3 weeks ago, still no word from them.
bit, camera, dslr, focus, k20d, lens, nikon, photography, picture, pictures, settings, sr
The Soft Place: Post Your Soft Focus Images jeffkpotter Mini-Challenges, Games, and Photo Stories 64 04-22-2014 05:39 PM
Question Soft Images fractal Site Suggestions and Help 2 07-13-2010 01:15 AM
Getting seemingly soft images. ManhattanProject Pentax DSLR Discussion 14 07-05-2010 08:53 AM
K-x with soft images harleynitelite Pentax DSLR Discussion 60 01-12-2010 02:19 PM
The Soft Place: Post Your Soft Focus Images jeffkpotter Post Your Photos! 22 04-23-2009 09:04 PM
All times are GMT -7. The time now is 10:44 AM. | See also: NikonForums.com, part of our network of photo forums!
