Originally posted by Pierrot All,
Well, well, ... thanks for the huge feedback. It'll take some time for me to read / study all this. Hope I will not have to dig too deep in my (long gone) engineering background to sort it out ...
I guess I'll go for the Eneloops first (or the Uniross Hybrio which should be similar I guess and much easier to find here in old Europe) since I do not shoot daily.
I'll keep you guys posted on any major improvements.
Thanks again.
Cheers,
P.
Why?!?!
I suppose that your camera shuts down at a higher voltage than others... if so, why bother trying the Eneloops? They still have the 4.8V output of NiMH. Even if they discharge slowly. The lithium cells will produce 6V.
Depending on your preference I suggest the following:
Energizer disposable lithium AA if you dont shoot a ton, and just want to immediately start having fun with the camera.
R-CRV3 (Moby or Delkin) if you really want rechargable and dont want to send your camera away for repair.
compare with other camera body at repair center or camera store, then send away to recalibrate... use Eneloops after if you want to, or either lithium cells...
But honestly I am not sure I see an advantage to the Eneloops over either lithium cells. they are cheaper to get started... I guess by half. but if you can afford to amortize the cost over the life of the battery the difference will be small on a per shot basis
-k
