Originally posted by kiwao I have a k10d and because I want large prints I try to use iso 100 as often as possible but have recently been advised that the difference between 100 and 200 is hardly noticeable so I should use iso 200 more often
I would appreciate any advice as to what and when are the advantages of using iso 200 over 100.
Regards
Michael
k10d, DA 70mm, FA 50mm, Sigma 17-70mm
Base iso is defined as having the most dynamic range which also means the least amount of noise. Any deviation, in either direction, starts the degradation of quality. Base iso for the k10 could actually be between iso100 and 200 so the difference may indeed be negligible.
Shoot whatever works the best for you.
