03-03-2009, 03:26 PM   #1
fs999's Avatar
My K20D on it self corrects aperture !
I noticed today when shooting the sun behind clouds, with my new DA 55-300, that my K20D, on it self, corrected the aperture from 5.6 to 18 despite I was in Av mode !
The aperture was set back to 5.6 after the shot.
The shutter speed was 1/4000" at 200iso. Click the image to see it on black !
03-03-2009, 03:44 PM   #2
That is almost certainly the result of setting the custom function "Auto EV compensation" to "On".
03-03-2009, 03:47 PM   #3
fs999's Avatar
That's an important feature ! Very intelligent !
03-03-2009, 03:53 PM   #4
Venturi's Avatar
QuoteOriginally posted by RBellavance Quote
That is almost certainly the result on setting the custom function "Auto EV compensation" to "On".
Beat me to it.
Custom Settings Menu -> 10. Auto EV Compensation
03-03-2009, 04:44 PM   #5
falconeye's Avatar
QuoteOriginally posted by fs999 Quote
It can make sense. If you don't want to care if your Av setting is possible within bright light.
However, in your sample, the image is underexposed, too...
EDIT:
Ah, I now see, why. You dialed in an exposure correction of -4EV.
So, if ISO200, 1/4000, f/5.6 and -4EV was a mission impossible, why do you complain your K20D made the best out of it?
03-03-2009, 10:21 PM   #6
Falconeye - Could not the -4EV be the result of the Auto EV compensation?
Jack
03-03-2009, 11:18 PM   #7
sinnettc's Avatar
QuoteOriginally posted by jbinpg Quote
Jack
Based on my brief tests last week the Auto EV is done through aperture adjustment, at least if you're in AV mode.
Chris
03-03-2009, 11:48 PM   #8
scary future
The cameras starts to do our work
03-04-2009, 01:30 PM   #9
kristoffon's Avatar
QuoteOriginally posted by sinnettc Quote
Chris
that makes no sense
what's the point of av then?
03-04-2009, 02:01 PM   #10
fs999's Avatar
I would say it is correctly exposed for not blowing highlights... Did you look at the photo on black ?
I am certainly not complaining, I was astonished, that's all
03-04-2009, 02:08 PM   #11
QuoteOriginally posted by kristoffon Quote
that makes no sense
This "Auto EV compensation" function (if enabled!) only kicks in where the chosen exposure parameters get "out of bounds" (eg. if the shutter speed would exceed 1/4000s, for instance).
03-04-2009, 05:03 PM   #12
falconeye's Avatar
Jack
No. Exif says -4EV exposure compensation was active (EXIF field 9204 "ExposureBiasValue"). But I invite you to google what can influence this value (except dialing it in).
Auto EV compensation (as I understand it -- and I can be wrong) actually is no compensation. The opposite, actually. It tries to maintain a correct EV exposure value by changing "the other parameter" if the predefined paramater (exposure time or aperture) has reached its limiting value.
Therefroe, with 1/4000s and -4EV, the camera had to ignore the f/5.6 setting and aim for something smaller.
The -4EV, in the first place, are most probably a simple user error...
EDIT...
I had a look at the EXIFs again. This image was the darkest in a bracketed exposure series. fs999 "forgot" to tell us about and I'm not amused... So, the -4EV wasn't dialed in but choosen by the bracket series. All else as I've said.
03-05-2009, 06:45 AM   #13
Mike Cash's Avatar
Chris
That would explain why I've never been able to get it to do a damned thing with a Takumar mounted.
03-05-2009, 12:18 PM   #14
fs999's Avatar
I am not amused either, I forgot it was in a braketing series, but this changes nothing to it, that at 1/4000" and f:5.6 the -2 EV shot was not possible without Auto EV compensation...
03-05-2009, 02:58 PM   #15
falconeye's Avatar
Franckly, I am now confused and don't understand your problem anymore. What did you expect, i.e., how did you want the camera behave?
Sidenote: I believe that the K20D, wehen doing an exposure bracket, changes both, aperture and exposure time, at least in M. Doesn't it do it as well in Av?
aperture, camera, dslr, k20d, photography, self
K20D and Flash Exposure Ed n Georgia Flashes, Lighting, and Studio 2 05-29-2010 01:19 AM
K20D Double-Exposure Adam_T4 Post Your Photos! 0 09-02-2009 04:13 PM
Is ti bad that K-7 only corrects DFA and DA lenses? Arpe Pentax DSLR Discussion 29 05-25-2009 09:18 AM
Multiple exposure on K20D Javaslinger Pentax DSLR Discussion 9 02-18-2009 02:33 AM
K20D Exposure wtlwdwgn Pentax DSLR Discussion 25 01-10-2009 12:29 PM
All times are GMT -7. The time now is 02:16 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
