03-07-2009, 06:46 PM   #1
K200D ISO when using built in flash?
Hello,
I recently acquired a new K200D. I have been using a K100D since a short time after it's introduction. I've noticed that when using the built in flash on the K200D, the camera, when the mode allows it, will choose a higher ISO than my K100D will shooting the same scene with the same lens. On both bodies I have ISO Auto set from min-max. Any one else using both bodies noticed this? I know the flashes on each body have different guide numbers, but they're close.
Thanks, BobG
03-08-2009, 08:27 AM   #2
Marc Sabatella's Avatar
My experiments suggest the K200D on auto ISO with flash chooses ISO 100 every single time when shooting outdoors, but chooses 400 or 800 indoors. Are you seeing something different?
I personally could not imagine ever using auto ISO, but even if I used it in some situations, I definitely would turn it off when using flash. Too easy for the camera to shoot itself in the foot by choosing an inappropriate ISO.
03-08-2009, 10:13 AM   #3
I only own a K100D and not the K200D - from the manul of the K100D - it says that under AUTO ISO the ISO is not corrected (not automatically adjusted) if the flash is discharged - which to me means that if the K100D is on AUTO ISO it will choose ISO200 - the base ISO.
The K200D appears to be a different animal - I can only go by the manual - there are no additonal comments for flash usage under AUTO ISO -
which probably means that the K200D is setting AUTO ISO even when flash is used -
and Marc's experience seems to indicate that - since outdoors will be bright so a tendency to have lower ISO, and indoors dimmer - therefore a tendency for higher ISO values.....
03-08-2009, 12:31 PM   #4
Thank you both for your insight. Because the note that appears in the K100D manual indicating the camera defaults to base ISO when using the built in flash (even if AUTO ISO is set) is omitted in the K200D manual, I now see that the K200D purposely functions differently and I have not set something incorrectly.
BobG
03-08-2009, 04:53 PM   #5
I might interpret this to mean, with Auto ISO, it picks an ISO *before* it fires the pre-flash, and does not then change its mind depending on the pre-flash result. That's how the K200D is, anyhow. Which does makes auto ISO pretty much useless with flash - it tends to pick unnecessarily too high indoors, and often too low outdoors (given that you're dealing with greater distances). I guess the K100D is even *more* useless if it really always picks 200.
03-08-2009, 08:53 PM   #6
That's about the size of it.
If I leave the K100D on Auto ISO - all my flash shots are at ISO200.
I actually wish it did the K200D thing......
03-09-2009, 09:50 AM   #7
Das Boot's Avatar
Are you using matrix metering? Is it different in center weighted or spot? I have a feeling the K200d is trying to "even" out the image by boosting the ISO. It's trying to expose more background light in a dark scene before it flashes would be my guess.
-Brian
03-09-2009, 01:10 PM   #8
QuoteOriginally posted by Das Boot Quote
I use center weighted metering. You're probably right about what it's trying to do, and that does indeed make sense indoors. Outdoors, though, it leads to counterintuitive situations when you get a less exposed picture with flash than without - with flash down, it will boost ISO as necessary if you've selected a small aperture, but it won't do that with flash up. Not that any of this matters to me - as I said, I can't imagine ever using auto ISO. But I can see why that behavior would surprise people, Just like the "feature" where dialing in exposure compensation used to disable auto ISO on older models - at least the K200D fixed that!
bodies, camera, dslr, iso, k100d, k200d, photography
In what situation can you use the external flash that the built in flash couldnt? rustynail925 Flashes, Lighting, and Studio 25 01-13-2010 01:26 PM
k200d built in flash dimid Troubleshooting and Beginner Help 7 10-13-2009 09:04 PM
K200D: using built-in flash to trigger optical slave? cheekygeek Pentax DSLR Discussion 5 07-01-2009 09:13 PM
K200d flash ISO deathspared Pentax DSLR Discussion 1 01-13-2009 01:28 AM
wireless flash using built in flash k200d dtra Flashes, Lighting, and Studio 3 04-04-2008 12:34 AM
All times are GMT -7. The time now is 09:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
