03-10-2009, 05:06 PM   #16
thats quite amazing, who would have thunk it hey!
03-10-2009, 06:31 PM   #17
krypticide's Avatar
Depending on what country you are in, the fluorescents will cycle either at 50 Hz or 60 Hz. Depending on when you catch the wave, you could potentially shoot at 1/100th or 1/120th and be okay.
03-11-2009, 06:43 AM   #18
rburgoss's Avatar
QuoteOriginally posted by krypticide Quote
I believe this statemente is wrong. Shooting at twice the speed of the light's frequency you will most likely "hit" the blackout between each light pulse. It you shoot at half the speed/frequency of the light source, will guarantee you will get at least one full pulse from the light source.
Think of it as flash sync speed. If you shoot at higher sync speed, you will get curtain blackout in some section. It shooting at sync speed or lower, you will always get the full burst and full frame. The issue here is that there is no possible way to sync the fluorescent lights with your shutter. If for some reason you get a properly exposed shot with fluorescent light at 1/100 sec or higher, then you can be sure it was an accident.
camera, degree, door, dslr, edge, photography, shots
Lens Tint StanW Pentax SLR Lens Discussion 7 01-19-2010 09:14 PM
Yellow Tint chilihead Troubleshooting and Beginner Help 9 10-18-2009 03:41 PM
K100 Super Manual Lens Yellow Tint/Overexposed??? Grzldvt Pentax SLR Lens Discussion 8 06-09-2009 05:13 PM
K20D, Yellow tint in middle of frame kasv Pentax DSLR Discussion 15 01-26-2009 09:58 AM
Battery grip causing weird readings? Inspection Guy Pentax Camera and Field Accessories 3 02-02-2008 09:25 AM
All times are GMT -7. The time now is 07:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
