03-10-2009, 01:33 AM   #1
what's causing this weird yellow tint ?
I was playing with my FA 50mm/1.4 this evening and noticed something strange.
Some shots of a kitchen cabinet door show this weird horizontal band of yellow tint.
Here it is around the upper middle of the camera:
This is pretty much the same shot, but now it's on the lower edge of the camera:
The next two shots of the same cabinet door don't have the problem, or to a much smaller degree (less tinting):
Here it is on the lower half of the camera:
Again, but to a smaller degree:
Here it is on the lower edge of the camera, after I've flipped the camera upside down:
Does anyone have a clue what's causing this ? I'm stumped.
03-10-2009, 02:08 AM   #2
RawheaD's Avatar
Strange indeed. Only happens with the 50/1,4? In which case, it's likely in the lens itself... can you remove the lens and look inside? Perhaps one of the elements came loose???
If it happens with other lenses, then it's clearly an issue with the body, and probably something to do with the sensor and/or firmware.
03-10-2009, 02:10 AM   #3
gazonk's Avatar
Weird
...but did you have a filter mounted? I wasn't thinking of a yellow gradual filter , but rather speculating (wildly!) if e.g. a polarizer used in ambient light could cause effects like this.
03-10-2009, 02:25 AM   #4
QuoteOriginally posted by RawheaD Quote
I don't see anything inside it. Nothing obviously loose. If I wiggle it, I do hear a little sound, but I don't see anything moving. Not sure if this is normal or not. I haven't really tested it with another lens yet as this it he first time I've noticed it.
QuoteOriginally posted by gazonk Quote
No filter mounted--well, except for a hoya uv/protector.
03-10-2009, 02:40 AM   #5
Remove the filter and snap a similar shot to see if the yellow cast is still there. If so, send it in.
03-10-2009, 02:53 AM   #6
why complain? I think the door looks a lot more nice with the yellow line
03-10-2009, 03:31 AM   #7
Lowell Goudge's Avatar
what is the light source?
While I didn't believe it at first, (I thought the phosphours coating on bulbs eliminated the flicker and color shifts, I was told by other forum members that depending on shutter speed, you could see large color shifts on flourescent bulbs. I took a shot of a tube and ou could see different colors along the legth as the slit of the shutter moved across the frame
03-10-2009, 03:39 AM   #8
QuoteOriginally posted by felixkh Quote
Ok, so it still has that problem without the uv protector. What's strange is, if I turn on the flash, the problem goes away. Also tried it with my 18-55 kit lens at a similar focal length, and there's no problem there. Weird..
50/1.4 with flash
18-55 kit lens
QuoteOriginally posted by losecontrol Quote
Lol
03-10-2009, 03:40 AM   #9
Oooh... the light source is from flourescent tubes directly overhead. Let me try a different shutter speed..
03-10-2009, 04:15 AM   #10
eaglem's Avatar
Is your White Balance set to Auto?? It looks like a White Balance problem.
03-10-2009, 04:23 AM   #11
QuoteOriginally posted by chiem Quote
Lowell, you're my hero. The flourescent flickering is exactly the problem.
For the curious, here are some shots at different shutter speeds:
50mm 1/160s
50mm 1/200s
50mm 1/250s
50mm 1/320s
50mm 1/400s
50mm 1/500s
50mm 1/640s
50mm 1/800s
50mm 1/1000s
50mm 1/1250s
50mm 1/1600s
The reason why flash wasn't affected should be obvious. The kit lens shot was at f5.6 1/60s. I learned something new tonight--I should never shoot faster than 1/160s around flourescent lighting.
03-10-2009, 09:44 AM   #12
Parallax's Avatar
This is what I'm betting on as well. Try duplicating the shot but use a slow shutter speed. I'll be surprised if it shows up at 1/30th of a second or slower.
03-10-2009, 01:42 PM   #13
QuoteOriginally posted by Parallax Quote
Yup, I'd bet a dollar that's the case.
If you're shooting in mixed light (natural light from the outdoors plus light from an artificial flickering warmer light source like some fluorescents) you can get results like these. The reason it only shows up on part of the picture is because the shutter mechanism takes some time to complete its travel -- and it moves vertically across the sensor, as your photos show. So the electric light is going from bright to dark or vice versa as the shutter does its thing, and you get yellow on part of your photo as the electric light is in its "bright" phase.
I have never seen this phenomenon quite so pronounced -- but still, I bet it's perfectly normal.
03-10-2009, 04:31 PM   #14
borno's Avatar
Well now I learned something today! Very interesting and something to watch for.
03-10-2009, 05:06 PM   #15
axl
1/160 it is!
I hope I'll remeber this as a rule of thumb....
camera, degree, door, dslr, edge, photography, shots
Lens Tint StanW Pentax SLR Lens Discussion 7 01-19-2010 09:14 PM
Yellow Tint chilihead Troubleshooting and Beginner Help 9 10-18-2009 03:41 PM
K100 Super Manual Lens Yellow Tint/Overexposed??? Grzldvt Pentax SLR Lens Discussion 8 06-09-2009 05:13 PM
K20D, Yellow tint in middle of frame kasv Pentax DSLR Discussion 15 01-26-2009 09:58 AM
Battery grip causing weird readings? Inspection Guy Pentax Camera and Field Accessories 3 02-02-2008 09:25 AM
All times are GMT -7. The time now is 09:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
