03-11-2009, 01:08 AM   #1
manual lens focal length
Hi,
I have a couple of manual lenses that I use but I jst want to check: when you start the camera (k20d but I think its the same as I had the same thing with K100) it asks you to set the focal length ... so do you:
- set the focal length as is ie 50mm is 50mm or
- set the focal length as multiplied by 1.5 ie 75mm
I assume its the latter but I just wanted to check.
thanks
03-11-2009, 01:16 AM   #2
I enter the the FL of the lens itself.
FYI - I think this is only for SR, because when my SR is off, it doesn't ask that.
T
03-11-2009, 01:24 AM   #3
ok, thanks. I always have SR on so I never noticed that.
03-11-2009, 04:16 AM - 1 Like   #4
pschlute's Avatar
You enter the focal length of the lens...ie 50mm.
A 50mm lens, whether a manual one made in 1980, or one made now specifically for the crop-sensor DSLR is still a 50 mm lens. Its focal length cannot change no matter what camera you mount it on.
50mm, camera, check, dslr, ie, length, photography
What focal length for a manual zoom? janstew Pentax SLR Lens Discussion 24 01-09-2011 08:26 AM
Manual lens focal length for shake reduction Riverlady Troubleshooting and Beginner Help 20 05-05-2009 03:16 PM
setting manual lens focal length on K20 boyscout Troubleshooting and Beginner Help 9 05-01-2009 08:55 AM
SR Focal Length Input for a Manual Zoom Lens? frank Pentax SLR Lens Discussion 13 03-15-2009 03:04 PM
Input focal length for a manual lens jpzk Photographic Technique 11 01-14-2009 08:50 PM
All times are GMT -7. The time now is 10:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
