03-13-2009, 02:31 PM   #1
K2000/K-m settings
Sorry if this has been asked before (I did a search), but any suggestions on best settings to start for shooting jpegs with the K2000? If adjusting the sharpness, should you adjust Sharpness or Fine Sharpness? FWIW, I use Natural mode with sharpness + 1 on my K10D (no Fine Sharpness option), but understand the jpeg engine is different with the K2000. I also shoot RAW or RAW+, but this camera is primarily for my wife who doesn't want to mess with post processing.
I know everyone has slightly different taste in jpegs, but was hoping to reduce the learning curve a bit for the K2000. I found it took a lot of trial and error to get results that I liked with the K10D, and it has fewer adjustment options than the K2000.
Thanks!
John
03-17-2009, 04:21 AM   #2
djm
I shoot same as on my K10 except that I use Fine sharpness
Bright, Sat -1 & Fine Sharp +1 pretty much the same but shapness a bit better on the edges. I do like a bit of punch to my shots.
03-17-2009, 08:27 AM   #3
I use "bright", +2 contrast, +2 sharpness.
Btw I don't really understand why there is sharpness and fine sharpness setting if they always get the same value If you set one of them to +1, the other one is also set to +1 automatically. So what's the point of having 2 settings if you can't adjust them indepently?
03-17-2009, 07:40 PM   #4
"Sharpness" level
The "sharpness" setting sets the amount of *sharpening* apply to the image. It does not and cannot change the amount of jpeg details as it is limited by the best jpeg compression setting as well as the quality and performance of the jpeg engine.
Shoot RAW and convert one-off to get the best image quality out of the camera.
QuoteOriginally posted by jrkeiser Quote
Thanks!
John
camera, dslr, jpegs, k10d, k2000, photography, settings, sharpness
K2000 Settings rustynail925 Troubleshooting and Beginner Help 19 11-16-2009 09:38 PM
I'm unhappy with K-7 settings. Help me custom the settings like k20. netuser Troubleshooting and Beginner Help 16 09-01-2009 08:39 AM
K2000 settings jon pafford Troubleshooting and Beginner Help 10 07-10-2009 01:33 PM
Just picked up a K2000. Any recommendations/advice on lenses and settings? philthy Troubleshooting and Beginner Help 9 06-02-2009 01:18 AM
K10D Custom Settings... Your Settings Gadget_Guy Pentax DSLR Discussion 4 05-25-2008 06:33 AM
All times are GMT -7. The time now is 10:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
