03-14-2009, 01:53 PM   #1
krypticide's Avatar
AF adjustment issue
So after botching a paid photoshoot because of bad focusing when shooting the FA 35mm f/2 wide open (I know, I know...), I decided to do the AF adjustment for all my lenses.
Problem is, all except one of them is at -10 (the exception is at -7)! And they are still front focusing slightly.
Is there something wrong with my body? Seems unlikely that all my lenses would be front-focusing.
03-14-2009, 03:53 PM   #2
Marc Sabatella's Avatar
If you're testing using tungsten lighting, then yes, every lens will front-focus slightly.
Causes of back&front-focus are still poorly understood (at least by me), but everything I've read suggests to me that *most* problems that occur would be with the body, not lenses, since the body is the brains behind the operation and in theory performs a double check of the focus. A misaligned AF sensor would indeed reuslts in all lenses being "off" in the same direction (if not the same amount).
03-14-2009, 03:58 PM   #3
Senior Moderator
Parallax's Avatar
With all of your lenses being off by essentially the same amount, and in the same direction, I would suspect a body issue but Marc is right about the lighting. If you haven't done so already, repeat the tests at or near infinity under natural or fluorescent light.
03-14-2009, 05:17 PM   #4
krypticide's Avatar
I'm doing it with a focus chart at 45 degrees and near minimum focus distance. I'm doing it under fluorescent light. I'll try under daylight and see if that helps.
03-14-2009, 05:37 PM   #5
krypticide's Avatar
Yep, same results as the first time. Going to call Pentax.
03-17-2009, 06:26 PM   #6
enoxatnep's Avatar
QuoteOriginally posted by krypticide Quote
I'd be a little wary of the results you get from those downloadable focus charts that ask you to set them up at 45 degrees. I was all freaked out by my 50mm f1.4 supposedly front-focusing, and no degree of in-camera AF adjustment worked. But then when I tested on real-world subjects that were perpendicular to the lens (text on a calendar, etc.), the AF was very good most of the time. (The AF would miss on occasion - no camera's perfect - but the in-focus shots were bang-on.)
Other threads in this forum have also indicated how the actual area of an AF point extends in a circle beyond the little red rectangle in the viewfinder, so your camera may indeed be locking focus on something above, below, or to one side of a focus point. This might give the impression as well that your AF is out of whack.
03-17-2009, 06:39 PM   #7
I would say it's a body issue. -10 is a SIGNIFICANT adjustment and if all the lenses except one are maxed out there you probably need to send your camera to Pentax for a little tweaking.
03-17-2009, 10:30 PM   #8
krypticide's Avatar
Just ordered a K20D from Amazon, will see if that one is better.
Also, I found Jeffrey Friedl's focus chart to be a better one, because it utilizes gray text (and you can pick the shade!) around a solitary black box, making it pretty much impossible for the AF point to mis-focus. The D70 test focus chart has a thin black box around the main black box, which might cause focus problems.
In any case, Jeff's focus chart also showed front focus beyond adjustment ranges.
03-19-2009, 07:39 AM   #9
NeverSatisfied's Avatar
Focus Charts
Hi Krypticide, say do you have a link for that focus chart you like? Some of us might be interested.
Have you tried Yvon Bourque's chart (Yvon is known as "K10DBook", if you search this forum)? I just used it to correct my K10D body using the debug menu, that whole experiment really was quite an interesting and satisfying experience. And FWIW, it all started AGAIN when I tried out my new FA 35 on the K10D (now relegated to back-up), "just for the heck of it", only to find that it was back-focusing! Darn that FA 35! (Actually an absoltely wonderful lens that has prompted me to work the bugs out of BOTH my camera bodies!)
Good luck
Paul
03-19-2009, 08:45 AM   #10
You can find Jeff's focus chart here:
Jeffrey Friedl’s Blog Jeffrey’s Autofocus Test Chart
03-19-2009, 01:16 PM   #11
I have seen this "debug menu" and "in-camera adjustment" reference before. Does the K200D have these?
03-19-2009, 01:34 PM   #12
QuoteOriginally posted by snofox Quote
No, just the K20D. Some older cameras can access a rather simplified adjustment menu via an undocumented "debug" menu meant to be used by service personnel only, but as far as I know, no one has figured out a way to access even that on the K200D. So if testing reveals a problem, the recourse is to send the camera and/or lens in for service.
My experience with focus testing is that it is *incredibly* easy to get wrong, and all sorts of people (myself included) have managed to convince themselves they are seeing focus problems that don't really exist.
03-19-2009, 01:49 PM   #13
I'm sorry to take this thread off-topic, but can I ask why tungsten lighting would make a lens front-focus?
03-19-2009, 02:52 PM   #14
Thanks Marc. That's why I never could find a debug prog. on my 200, not that I think I need one.
Every time I think that I have front focus issues I find that I am shooting close up and wide open at f 1.4 with a normal lens, such as the FA 50. A flower's pistils are clear and sharp, but the rest of the lily is blurred. DOH!!
03-19-2009, 03:56 PM   #15
Get a...
So after botching a paid photoshoot because of bad focusing ...
Katz-eye, or one of the $29 Chinese knock-off focusing screens, install it, and 'presto'... no more focusing problems... ever!
Cheers...
adjustment, af, af adjustment, camera, dslr, lenses, photography
Vivitar MC Tele Converter 2X PK-A/R-PK issue...or no issue? WiseOx Pentax SLR Lens Discussion 5 06-11-2014 01:14 PM
Af adjustment Alex00 Pentax SLR Lens Discussion 8 04-20-2010 03:36 PM
AF Adjustment skid2964 Pentax DSLR Discussion 14 10-22-2009 03:51 PM
AF adjustment - am I doing it right? jesalonen Pentax DSLR Discussion 15 01-31-2009 07:37 AM
A printer issue, or a processing issue... FHPhotographer Digital Processing, Software, and Printing 0 10-03-2008 12:13 PM
All times are GMT -7. The time now is 10:06 AM. | See also: NikonForums.com, part of our network of photo forums!
