Originally posted by wasim_altaf What re-starts AF after it has been cancelled? Does it need to be turned off again in between the two series of shots described above?
I do not know - I have never let used the AF button to disable AF. Just plain can't answer that one.
Originally posted by wasim_altaf Another thing to consider is which control dial is primarily being used. AF button doesn't work well for me if I'm using the rear e-dial -- I often end up on the EV-comp button. I run into a far more serious problem if I re-program the front e-dial to be the primary control wheel -- I have a tendency to mistake the power on/off button as the front e-dial sometimes, when moving back from the shutter, thereby shutting the camera down. Then there is the grip, which doesn't have its own AF button.
I use AV most of the time - so the rear e-dial is the f-stop. I usually set the f-stop before I get the camera up to my eye - so hitting the AF button with my thumb (I use the center AF all the time) has become second nature to me as of late. (On my *ist Ds I use the OK button to force AF). As mentioned above - I do not have a grip -- in so may ways too -- so I just do not care.
Originally posted by wasim_altaf On the other hand, holding the shutter half-pressed feels like riding the clutch. Sometime it seems to me -- correct me if I'm wrong here -- that if the shutter is held half-pressed too long, it can come out of lock and restart AF, or starts to micro-adjust focus continously (you can hear the motor grinding away). This may be more damaging than anything else.
In any case, and despite the fact that I have not yet done so, my impression is that decoupling AF from the shutter is the way to go. It's just a matter of getting used to it, eventually.
I agree that holding down the shutter button is somewhat like riding the clutch. But then between most of my shots I shut the camera off (ya know - with the off switch). So with my style of shooting I do not have the shutter half pressed all that much. I usually try to anticipate when I am going to take an image, so the camera is powered up when it goes up to my eye.
As for losing AF while holding the shutter button down - I have bumped the focus ring and had to "refocus" - more that I would like to admit. However, with the shutter button? Once I learned how to use the OK button on my *ist Ds, I never went back. On my K10D and K20D the first thing I did once the battery was charged and I set the date/time - was de-couple AF from the shutter button. I have no experience with losing focus lock with shutter button only on the K10D and K20D.
Old habits die hard. (Your mileage will vary)
The Elitist - Formerly known as PDL
