Originally posted by lesmore49 I have a K10D and a 55-300 mm Pentax zoom. [...] I usually put my meter on spotmeter, use my shutter priority setting at about 1/640th for wing blur control and running action and put my automatic focus on continuous. I don't worry about a lot of depth of field, as my subjects are primarily animals/birds and I want to isolate them in the pictures. I've generally happy with the results, but wonder if any have recommendations for different settings...which may improve the end result.
Well, I'm more likely to do things a bit differently:
1. I usually meter by multisegment (dialing in exposure comp + or - depending on the situation).
2. Sometimes I use program (especially in bright light and/or when I can't concentrate on exposures), or I use aperture priority (to keep the aperture at a "sharp-as-possible" f/8 to f/10 or so - I need the ability to crop quite a bit on occasion), or sometimes, if the light is pretty steady (both in direction and intensity), I'll switch over to manual exposure and avoid the exposure comp juggling altogether.
3. If the subject is sitting still in a tree, say, I'll switch to AF-S, but if the subject is moving, I'll switch to AF-C.
4. If the subject is moving around (especially a flying bird), I'll switch to auto focus point, but if the subject can be centered reliably, I'll switch to center focus point.
