04-06-2007, 06:13 PM   #1
matix's Avatar
K10D and AF-360FGZ anomoly
Hi all.. need help with a question. I have a K10D and the AF-360FGZ flash which for some reason does not work always as described in the manual.
The problem is, with all the right settings on the camera and the flash the Auto Zoom setting for P-TTL will not set from Manual Zoom automatically, nor can it be set by the Zoom button as instructed.
The next time I use the camera, is seems to be fine. I can not remember changing any setting, using P mode or Green mode there is no difference.
The P-TTL is on fine, and the flash works fine, but without the Auto Zoom on the flash being set, the flash zoom does not. I have a second flash, same problem.
Anyone seen this before?
04-06-2007, 06:37 PM   #2
Not sure if I understand your problem exactly, but Auto Zoom has been working fine so far for me.
04-06-2007, 07:16 PM   #3
matix's Avatar
A.Zoom not working on AF-360FZ
QuoteOriginally posted by nosnoop Quote
Simple to explain.. set camera as normal, put on the external flash and turn it on. It should, and sometime does, set the Zoom mode to A.Zoom. Right now, it sets to M.Zoom and the flash zoom in the head does not move.
Is on P-TTL and all settings are by the book and as done before.
Weird.
04-07-2007, 04:38 AM   #4
philmorley's Avatar
QuoteOriginally posted by matix Quote
is the diffuser down / bounce card out having it down will down will stop zooming (catches me out regularly
phil
04-07-2007, 05:25 AM   #5
One member here recently had problems with multiple copies of this flash. Similar problems which each copy. Not sure if he ever got it resolved satisfactorly.
Walt
04-07-2007, 01:34 PM   #6
matix's Avatar
Problem Solved - Thanks Phil
QuoteOriginally posted by philmorley Quote
phil
That was the problem, if the diffuser or white bounce card is out, the flash zoom A.Zoom no longer can be enabled. Makes sense, would have been nice to have that in the manual...Thanks!!!!
All sorted now.
Phil
04-07-2007, 04:18 PM   #7
matix's Avatar
All sorted now.
Phil
And another oops.. it is mentioned in the manual, but only in relationship to the Bounce card and Diffuser usage. Pages 17 and 53,
af-360fgz, auto, camera, dslr, flash, k10d, mode, p-ttl, photography
For Sale - Sold: All Brand New: K10D, K20D, AF-360fgz! PrimeObjectif Sold Items 22 05-15-2009 11:14 AM
For Sale - Sold: K10D body (AF-360FGZ Flash too if wanted) mrpackerguy Sold Items 2 10-09-2008 01:50 PM
k10d and flash af-360fgz enrod666 Pentax DSLR Discussion 8 06-13-2008 04:52 PM
K10d Anomoly? Or me? Bramela Pentax DSLR Discussion 16 03-02-2008 04:29 AM
360FGZ or 540FGZ for a K10D calicojack Pentax Camera and Field Accessories 8 09-02-2007 11:22 PM
All times are GMT -7. The time now is 01:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
