03-21-2009, 10:18 AM   #1
K100D problem?
I'm having issues with my K100D not switching on, even with fresh fully charged AAs. I have had a couple of instances in the past where it flashed with 'battery depleted' but a switch off and on again and it was fine, but today I have had problems even getting the thing to switch on. I'm not sure whether it is a battery compartment issue, or the on/off switch.
Has anyone here encountered a similar issue?
03-21-2009, 12:47 PM   #2
Marc Sabatella's Avatar
How old are the batteries? As they age, they can't charge as fully, and Pentax DSLR's are notorious picky about voltage levels - a battery may be charged fully enough to work with other devices, but not have enough voltage for your camera. In general, rechargeable batteries that aren't "Eneloop" or simialr low-self-discharge types should be phased out in favor the newer technology.
03-21-2009, 02:24 PM   #3
Senior Moderator
Parallax's Avatar
In addition to what Marc said, try cleaning you battery terminals (in the camera and on the batteries themselves) with a pencil eraser.
03-21-2009, 04:15 PM   #4
Zou,
I reckon Mark has said it all. I have a K100d and exactly the same problem started about six months ago. I changed to Eneloops and the problem has gone. K100`s do seem to have this problem, when the old (fully charged) batteries would not fire up the Pentax I would put them in my wifes Fuji 6500 and it would work OK.
Richard.
03-22-2009, 02:10 AM   #5
Zou
Thanks
I've had a play about and it seems the contacts in the battery compartment cover were perhaps not touching the batteries correctly. I 'lifted' them a bit with my fingernail and all seems ok again.
I'll bear in mind the battery age thing though, that may well come into play at some point.
I have to admit that things like this are exactly why I have always preferred fully manual mechanical cameras - every camera I have ever owned which relied on electronics has died, but hopefully the K100D has life in it yet!
03-22-2009, 12:03 PM   #6
Pleased to hear you have it sorted. The K100d will last for ages, at least I hope so.
Richard.
camera, dslr, issue, k100d, photography, switch
Problem with K100D AF mummarazzi Pentax DSLR Discussion 2 11-06-2010 09:59 PM
K100D AF problem DisneydaveCT Pentax DSLR Discussion 2 03-30-2009 10:14 AM
Problem with K100d super. Darcygirl Troubleshooting and Beginner Help 4 02-01-2009 09:25 PM
Help!! I think my k100d has a problem! barbosas Pentax DSLR Discussion 3 05-21-2007 03:20 PM
problem with K100D Branimir Pentax DSLR Discussion 15 12-20-2006 11:05 AM
All times are GMT -7. The time now is 03:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
