Originally posted by Richdog Holy sheite that looks like a beautiful flashgun! Forgive my ignorance (still learning) but what exactly is the P-TTL adapter?
Metz make different adaptors so you can use the same flash gun with different cameras.
In the film days, most camera makers made TTL (through the lens) metering for flash by having a small sensor in the body measuring the light off the surface of the film and correctly exposing accordingly. It was an analog system and was fine for film speeds up to ISO 400.
When digital came along, most camera makers dropped TTL metering and devised more sophisticated digital systems (Canons E-TTL and Nikons i-TTL) which used metering through the lens but instead of metering off the surface of the imaging sensor which gave unreliable metering results, they used a pre-flash from the gun to calculate the correct exposure, other features such as hi-speed synchronisation were easier to implement.
Pentax fitted TTL sensors to their fist digital bodies (the istD and DS), they were the last manufacturers to do so, but more recently have adopted their digital TTL called P-TTL and dropped TTL support, much to the annoyance of some diehard supporters of TTL. The TTL performance in the D and DS was moderately okay up to ISO 400, but not so hot at higher ISO's. I found that using the Auto mode of metering using the flashguns own exposure sensor more accurate and reliable. This is what I use with my K10D.
Metz have TTL support for their SCA 3000 series of adaptors (SCA-3702 for Pentax) but we are awaiting an upgrade for P-TTL support from them. They have i-TTL and E-TTL adaptors for Nikon, Canon and also for Olympus digital now, so hopefully we can expect them to release one for Pentax in the future. When? Only Metz know that answer!
Another feature is that the Pentax guns have built-in wireless flash control that can be triggered by the pop-up flash.
The Metz guns require a wireless slave adaptor (SCA 3083) to be fitted instead of the camera adaptor, the slave units can then be fired by another MZ54 on the camera. I haven't tried using the camera pop-up flash to trigger a SCA 3083 equipped slave flash gun. I shall have to see if I can find one at a dealer to try.
If I was to buy a flashgun system today, I would probably buy into the Pentax AF 560FGZ, even if Metz had P-TTL support.
