Awhile back there was a thread about using a program from Germany called Startrails (
www.Startrails.de) to simulate long exposures of the night sky. At the time I had nothing longer than 30 minutes to show. It took this long for me to be at a dark site with a clear sky. Star Trails are intolerant of even a single passing cloud.
This was taken at a Boy Scout Camp in Goshen CT. I waited until the Scouts were asleep. The camera took 212 thirty second exposures using a Pentax K100D, Vivitar 19mm F3.5 lens, Bogan tripod, Pentax AC supply, and Pentax manual cable release. I set the camera to Manual, Continuous, no NR, and locked the remote. I then went off to do some imaging with my K110D. This is just shy of a two hour exposure during which the Earth rotated 30 degrees. Long exposures bring out the color in stars.
Things I could have done better would be to include some foreground scenery and take some dark frames. It was 3 AM, I wasn't thinking clearly.
This type of photography is easy to do once you have a dark location to set up. I should note with this wide lens NO stars appeared in the viewfinder or LCD display. The sharp dots are too small to see without Zoom. I had to focus by setting the lens to infinity which would not be accurate enough for a longer focal length lens.
Reason: fixed url
