03-23-2009, 05:48 PM   #1
Is this normal?
I am not sure, because I didn't notice it earlier. When I shake my camera in my hand I can hear the sensor and the whole mechanical unit move inside the camera. Something similar to the dust removal not as bad as that. It happens even when the camera is turned off. Do you feel any thing moving when you shake your camera. It is a Pentax K200D.
Thanks
03-23-2009, 06:07 PM   #2
Try turning anti shake off before turning the camera off and see if that changes anything at all. If not, and anti shake is working.. I wouldn't worry until you run int problems. My k20d does not make any noise. My k100d does, although it took a few spills on pavement and still operates like a champ.
03-23-2009, 06:14 PM   #3
yep...google "k10d sensor clunk" :-)
03-23-2009, 06:35 PM   #4
Andi Lo's Avatar
I called pentax canada early in my ownership and they confirmed that this is normal behaviour from the shake reduction, even when off.
03-23-2009, 06:40 PM   #5
Robert S Donovan's Avatar
The sensor is floating in the SR mechanism so that it can move to cancel camera movement.
04-01-2009, 11:34 PM   #6
Thanks for the responses I was really worried
camera, dslr, photography
Is this normal? kangamel Troubleshooting and Beginner Help 7 06-15-2010 06:36 AM
Is this Normal? willyflyboy Pentax DSLR Discussion 2 02-21-2009 05:36 AM
HELP! Is this normal? PNTXFTW12 Pentax SLR Lens Discussion 8 12-16-2008 09:13 PM
Please help! I need to know if this is normal. newpen Pentax DSLR Discussion 7 03-21-2007 12:27 PM
All times are GMT -7. The time now is 03:30 PM. | See also: NikonForums.com, part of our network of photo forums!
