Originally posted by fkaufman George, I understand from the pictures that the SMD connector came loose from the circuit board that has the SD card socket. Did you manage to pry the connector out of its socket and solder it tback onto the board?
Frank,
I did not even try to repair this. the SMD connector ripped from the camera main PCB took also some solderpads and wiring from the main PCB.
This shows the SDcard PCB with the 2 connectors :
This the main PCB :
If you look closely at the place where the connector should be, you see via's below the connector.
Repairing this is beyond my capabilities. If I had the electronic diagrams, and knew where these SD connector wires filnally end, I could make new wires, but now I use this camera with remote assistant.
This SDCARD failure after a 'bump' is a known problem with the K10D.
This is caused by the SD card print being mounted on the battery assembly, which is heavy when a battery is inserted.
A bump will flex the camera/battery housing, and such a PCB connector cannot cope with force. Pentax shoud have used a flex foil connection to the SDcard print.
George
