Originally posted by Fl_Gulfer Smart answer, I didn't consider that a shot with half of it is blue sky would have less info.
My College Photography teacher said is was bad for the cards to format them every time, and I found that hard to believe.
Thanks Again Guys
Jack
The answer to that is either yes with a "but" or no with an "if".
Yes, it's bad in the sense that all flash memory has a limited lifespan, so the additional writes do technically make the card die sooner, but that's not a significant enough of a concern to change your behavior.
No, if you use your card like most people do, you're far more likely to have a failure that results in losing data from handling outside of the camera, and starting with a fresh file system gives you the best chance for data recovery and not having file system problems in the first place. Volatile memory is notoriously error prone, so improving your odds at the expense of a slight difference in expected life is a good trade.
