05-07-2009, 06:10 PM   #256
distudio's Avatar
QuoteOriginally posted by ManuH Quote
Pentax AF-C can also be made slightly faster if one is using the central point only. When using the auto-points it's slower. That may confirm the weak non-dedicated to AF CPU theory.
Is it confirmed that Pentax do not currently use a dedicated focus processing CPU?
05-07-2009, 06:49 PM   #257
Duplo's Avatar
And lens AF speed (SDM or screw). BTW speaking of the lenses the in-lens stabilsation also favors AF speed: the image is stabilised so there is less work for the AF sensors.
I had that included in an earlier post, but yeah lenses plays an important part of it.
And to add to the confusion the one being the fastest to aquire focus, may not be the best at tracking a moving subject
05-07-2009, 06:51 PM   #258
Duplo's Avatar
QuoteOriginally posted by distudio Quote
Hi Rob,
No I do not think there is an official word on it, at least I have not heard any, but steves observations, mentioned earlier in this thread seems to support the theory.
05-07-2009, 06:54 PM   #259
*isteve's Avatar
No, but if they are its sharing resources with the main CPU because in AFC mode it cannot manage anything like 3fps even oif you are not moving, and in single shot mode there is a notable delay after the shot is taken before AF "gets going" again. On a Canon 1D mk2, there is no such delay and shooting speed in Servo mode seems unaffected.
None of this is proof, of course. But it seemed interesting.
05-07-2009, 07:36 PM   #260
ManuH's Avatar
QuoteOriginally posted by *isteve Quote
But in the past, film cameras could focus rather fast and certainly the processors were not as powerful as today. Is there so much calculations anyway? Maybe in a true tracking system but certainly not in the current implentation of Pentax AF-C.
And I don't seem to notice any AF delay after a shot is taken on my K20D. But it's true that in AF-C you rarely get the full 3fps (makes me wonder if a 5fps+ Pentax would be such a good idea anyway).
05-07-2009, 07:46 PM   #261
*isteve's Avatar
No, but the only two CPUs were for the metering system and the AF system and they were largely independent.
Modern SLRs have a central CPU and a considerable amounbt of software controlling everything from menus to WB correction, noise control, Bayer interpolation etc.
If the same CPU is being used for all functions - or the system bus is being shared - then this would seem like a good reason why SLRs dont seem as fast as some of the old film bodies.
If you set the camera in AFC mode and single shot mode, pick an object about 20 feet away and walk towards it noting the rate at which the focus adjusts (on an SDM lens like the 16-50 its quite fast). Now repeat but take a shot half way. I could swear the adjustments pause or slow down temporarily.
05-08-2009, 02:35 AM   #262
danielchtong's Avatar
You will see that when you do AF-C & burst with moving subject. The worst case is AF-C, burst & fast moving subject in changing lighting condition. The worst case means your subject is gone without you taking even one shot.
Yes. You get the full 3fps even in AF-c & burst when you shoot stationary subject.
The best I can do with AF-C & burst was 1 fps with DA200mm & K20D in
Actions shots DA200mm - Photo.net Pentax Forum
I can only get 3fps for moving subject with full manual focus and exposure. That I am afraid is like a theoretical fastest speed of Corolla at 140 mph
Daniel
05-08-2009, 05:39 AM   #263
ManuH's Avatar
QuoteOriginally posted by danielchtong Quote
I know that AF-C in burst mode, the camera will sometimes pause between the shots but I always thought it was to adjust the focus. And with a screwdrive lens you can hear the noise during this pause. At least the K20D tries to get each shot in focus, my K10D seemed to not care if the shot was in focus or not in a burst.
If like you say it's processor dependent, then there is some hope for improvements because they get faster all the time and it doesn't cost a lot of R&D (for those who will buy the chip).
05-08-2009, 05:53 AM   #264
Howard's Avatar
Slow AF speed gives you time to think. For me, I have never given that a socond thought. Its a Pentax, it is good enough for me, as there is no other option. Then again, it seem to me that the press are allways looking to a way to bring the Pentax reputation down.
Which you cant do. You just cant.
05-09-2009, 04:26 AM   #265
Here is some suggested recipe for improving AF of any Pentax without hoping for the next AF revolution. And I mean now.
Instead of auto, shoot manual exposure , fixed iso 800 and spot focus.
In shooting kids running around in not quite contracting lighting situation, the fact that shooting in M mode will shave a split second from the hunting time.
I think we are heading back to the main subject line.
Or alternatively, go for the more expensive route of 1Ds or D3x. And do not even think Pentax will remain in present Pentax pricing if it reaches 1Ds or D3x performance parameter. That is a business world
Daniel
05-09-2009, 07:51 AM   #266
Duplo's Avatar
Good advise Daniel.
Daniel
Well I do not think anybody here, or at least I am not, expecting them to reach that level. Or if they do stay at the current pricepoint.
II can only speak for my self, but I have never been dissatisfied with the pentax system, given its price/performance ratio, quite the opposite in fact, otherwise I would not run it alongside my nikon system.
05-09-2009, 08:42 AM   #267
Wheatfield's Avatar
QuoteOriginally posted by Howard Quote
I prefer to do my thinking before I push the button. After that, it's the camera's turn to think.
05-09-2009, 02:18 PM   #268
distudio's Avatar
Otherwise you may as well simply manual focus ;-)
05-09-2009, 05:51 PM   #269
ManuH's Avatar
Interesting. Is it something you tested yourself? ISO 800 may not be quite a good idea if we want to save CPU cycles as some say that some NR occurs at 800 and above (on the K10D, K200D, K-m).
05-09-2009, 06:41 PM   #270
Now we've wandered into the realm where I can't tell if it's sarcasm or not...
af, camera, dslr, photography
KX complaints-soft pics-SR issues-etc harleynitelite Pentax DSLR Discussion 4 01-20-2010 10:33 PM
Ebay complaints Jim Ryan General Talk 11 10-09-2009 11:01 AM
K10D complaints/K20D fixes codiac2600 Pentax DSLR Discussion 46 02-12-2008 02:47 AM
sick wildherre Post Your Photos! 6 02-23-2007 04:06 PM
All times are GMT -7. The time now is 09:10 AM. | See also: NikonForums.com, part of our network of photo forums!
