04-02-2009, 05:27 AM   #1
Remote assistance and Live view
please clarify some things to me.. is it possible to view live view with remote assistance on my computer screen with k20d?
and is it possible to change focusing points in remote assistance?
thanks.
04-02-2009, 05:29 AM   #2
soccerjoe5's Avatar
You can't do live view when plugged to the computer.
Try using a TV. SO much better you won't go back to using the computer.
04-02-2009, 05:59 AM   #3
LeoTaylor's Avatar
QuoteOriginally posted by soccerjoe5 Quote
I'll vouch for that! Though a TV/Video Monitor won't fit all situations I've been using one several months in my astronomical observatory. I had a 13 in diagonal CRT TV left over from the Digital Broadcast Conversion and tried putting it on a stand next to my telescope. The jump from a 2.5 inch to 13 inch display means I can focus many times faster. I can also check the final photos on the large screen without having to connect the USB cable, load onto a computer, convert from RAW, increase the brightness, then disconnect for the next shot.
One weakness of my K110D (and I presume other Pentax cameras) is once you connect the USB all camera controls go dead. Connect the video cable only blocks the LCD screen. Note: if the cable is connected and the monitor is off it can be a bit disconcerting.
04-02-2009, 07:13 AM   #4
what kind of res tv does it support? 1080p? :P
04-12-2009, 07:22 PM   #5
LeoTaylor's Avatar
QuoteOriginally posted by WerTicus Quote
No. I think Sony makes a big deal about one of their cameras that outputs Hi Definition Video.
The object here is to use a cheap monitor (free if it is an analog TV being replaced with digital) to aid in focusing, framing, etc. The K100D outputs NTSC or PAL, both are analog signals (about 480i in the U.S.). Most any TV with a composite video input (usually a yellow RCA/Phono jack) will work.
04-12-2009, 10:13 PM   #6
QuoteOriginally posted by Mystic Quote
thanks.
No, you can't use live view with remote assistance nor chose AF points. I know.
assistance, camera, dslr, photography, view
K20D Not Recognized by Remote Assistance LeeHolliday Pentax SLR Lens Discussion 4 08-25-2009 01:15 PM
Remote Assistance and K20D M Vlosich Pentax DSLR Discussion 3 03-14-2009 04:37 PM
Remote Assistance on *istDL pk5 Photographic Technique 2 09-14-2008 05:44 PM
k10d remote assistance? kww_2007 Pentax DSLR Discussion 8 05-18-2008 08:29 AM
K100d remote assistance question Broonie Pentax DSLR Discussion 12 10-18-2007 11:12 AM
All times are GMT -7. The time now is 03:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
