04-11-2007, 08:43 PM   #1
Flash tips
I just purchased my first external flash unit, a 360. I thought it might be a good idea to create this thread for us to share tips on flash photography, and seek advice.
To start off, can someone explain how the Zoom on the flash works? I noticed that the reading on the flash isn't my lens' focal length, why?
Also, why does it go into Manual zoom mode when i flip down the diffuser?
Thanks, Peter.
04-11-2007, 08:49 PM   #2
-=JoN=-'s Avatar
zoom on the flash head doesnt really match up to the actual lens Focal Le.
stops @ 58 i think (on my 540 anyway)as far as anything else behind it. i really dont know..:ugh:
and for the diffuser...when flipped down it zooms back to it's widest setting.
spose to um...spread the light out more in closer situations (i think ). an after market diffuser would work better ( like a stofen)
I usually bounce......bounce, bounce bounce.....
if there is something to bounce it off of...i bounce it. better results.
it's really fun when you start using manual lenses.....
04-11-2007, 11:41 PM   #3
Matjazz's Avatar
I have 360 and the focal lenght displayed on flash is the 35mm equivalent to the focal lenght of 1.5 crop sensor.
04-11-2007, 11:53 PM   #4
QuoteOriginally posted by nystateofmind27 Quote
Thanks, Peter.
First piece of advice i an give, avoid pointing the flash at the subject you intend to take the photo of, always bounce it off the ceiling.
The zoom focuses the flash so it will cover the area of view that the lens does, this enables the lens to function more efficiently.
The Diffuser that comes with the flash is a wide angle diffuser, is spreads the flash out so it can be used with wider lenses.
04-12-2007, 07:09 AM   #5
Lowell Goudge's Avatar
QuoteOriginally posted by -=JoN=- Quote
I have had a long discussion with Pentax about this issue (flash zoom length and lens focal length)
It seems that the flash on some lenses displays the lens focal length, and on other lenses it displays the effective (35mm equivelent) focal length for the cropped sensor.
In the end, I don't care as long as the flash coverage is correct for the focal length, and providing that power is not wasted by too wide a coverage (although some of my friends like the indirect lighting that results)
In the end, I don't bother looking unless I am using a K mount lens, and want to insure that I have the correct length selected.
to that end, perhaps a software modification is in order. When you mount a non automatic lens (K mount) on the K10D you are prompted at power up for focal length. Why can't the camera set the flash to this length?
04-12-2007, 01:09 PM   #6
roy
roy's Avatar
it's because the older lenses are stupid. they don't talk to the body or the flash. they're mute.
camera, dslr, flash, photography, tips
Comments and Tips are welcome! Kai Post Your Photos! 8 10-07-2009 05:23 PM
Tips on ebay K-7 AMBIVALENCE Photographic Technique 10 08-18-2009 12:35 PM
Tips for using non-ttl flash off camera F8&Bthere Photographic Technique 15 08-16-2009 06:04 AM
Share your Cactus Wireless Flash Trigger Tips philbaum Flashes, Lighting, and Studio 21 12-05-2008 08:53 PM
Top 5 (or more) tips paolo g Pentax DSLR Discussion 21 06-19-2008 10:54 AM
All times are GMT -7. The time now is 04:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
