04-12-2007, 04:16 AM   #1
K10D, 540 flash and pocket wizards?
I want to use the pocket wizards to trigger the 540 flash...I noticed the connector on the 540 is a round female connector for 5 or 6 pins or something like that. What type cable would I need to go from the mini plug on the PW to the 540 flash? Thanks.
04-12-2007, 04:43 AM   #2
It is a proprietary cord made by Pentax. You will have to get it from them.
Walt
04-12-2007, 05:04 AM   #3
Matjazz's Avatar
I have that China wireless trigger and was always wondering what Pocket wizard can do that its alternative can't?
04-12-2007, 06:16 AM   #4
jfdavis58's Avatar
Don't know, maybe you can tell me.
PW have 4 or 32 channels,
they can remote fire a flash,
they can chain to lengthen the flash to camera distance,
they can fire a camera on one channel subsequently firing one or more flashes on a second channel,
you can set one flash or bank of flashes on each channel and select which to fire from the camera.
They seem to have the fastest response time, thereby allowing the fastest shutter speed sync-see the manuals l for more specifics.
04-12-2007, 09:18 AM   #5
I dont think there is a cord to connect a PC socket to the Pentax plug. I don't use my radio trigger with my 540, not directly anyway. I use it with my 285HV and set the 540 to slave. If anyone knows of a PC to Pentax cord I would love to hear about it.
04-13-2007, 04:54 AM   #6
Matjazz's Avatar
Well, the wireless China trigger fires the flash with less than 1/60sec delay (haven't tested with faster shutter speeds) and can have up to 16 channels. I have single channel version which serves me well. The only thing I'd like to have is more range.
I thought that pocket wizards are able of TTL, P-TTL operating. A sort of wireless cable replacement.
04-13-2007, 06:36 AM   #7
jfdavis58's Avatar
No, the PW +II is strictly manual operation; their signal is independent of the camera. If the remote flash is capable of auto-i.e. something like the 283/285 thyrister circuitry--then you have auto.
As to the notion of a Pentax 5-wire to PC type cord one can be hacked or cobbled together from the Pentax hotshoe to PC cord adapter sold as a PZ accessory a cable and a second modern hotshoe to five wire adapter (the one that looks like a truncated ski-boot). And expensive 'mod'-about $100.00US. It doesn't matter which end one attaches to the adapter-once the circiut closes the flash fires.
04-14-2007, 03:44 AM   #8
I found a suitable hot-shoe base for the flash on ebay. The base has two plugs for the standard PC connector, and a threaded hole on the bottom for mounting it on a tripod. Most of the base is plastic, so the extra pins on the flash unit mounting foot do not ground out. You will need a connector cord with a PC plug on one end and with whatever your radio trigger device needs on the other end.
Of course, with ebay-type or Pocket-Wizard radio triggers, the flash can only be used in auto or manual modes; there can be no communication with the camera to control TTL or P-TTL exposure.
camera, connector, dslr, flash, photography, pocket
need pocket wizards for Metz 58? kewpie-o Flashes, Lighting, and Studio 6 03-04-2010 12:10 PM
V2's Pocket wizards, Skyports etc Which do you have and use? Peter Zack Pentax Camera and Field Accessories 24 05-24-2008 05:59 PM
K10 + 540 Flash + Pocket Wizard pcfranchina Pentax DSLR Discussion 10 05-21-2008 05:39 AM
TSA and Pocket Wizards roscot General Talk 8 11-13-2007 07:21 PM
Just got pocket wizards and have a question on K10D sharpshoota Pentax DSLR Discussion 6 04-11-2007 05:59 PM
All times are GMT -7. The time now is 07:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
