04-18-2009, 07:30 PM   #1
Going back to firmware 1.02 on K10D?
Hi,
I purchased a 50-135 last fall and I just love it. However, I noticed that many users encounter problems with SDM. If, in two years, SDM of this lens fails, is it possible to revert to firmware 1.02 so that I can use this lens without SDM ? And if so, where can I find the 1.02 version and the instructions necessary to install it?
Regards,
04-18-2009, 11:18 PM   #2
IIRC, the SDM is on the lens and not in firmware on the K10D. You may not be able to use the lens without SDM
04-19-2009, 10:24 AM   #3
res3567's Avatar
QuoteOriginally posted by felixkh Quote
The lens may have the "screwdriver slot" I have not researched this. If it does, it is backward compatible with older bodies that don't have the contacts for the SDM Lenses. Is the slot that couples the lens to the motor in the body.
04-19-2009, 12:31 PM   #4
axl
I believe 50-135 does have screwdrive and as such should be OK with K10D older than 1.03 and with K100/110 and *ist D bodies...
BR
PS: for the firmware, chceck the official Pentax site, or do they show only the newest firmware?
04-19-2009, 12:40 PM   #5
I like it when manufacturers don't REMOVE older firmware from their download sites.
K10D Firmware 1.20
For Windows:
http://www.pentax.jp/english/support/digital/firmware/k10e120w.exe
For OS X
http://www.pentax.jp/english/support/digital/firmware/k10e120m.hqx
04-19-2009, 07:19 PM   #6
Thaks for the link. As far as I know, the 50-135 does have screwdrive. And so do the DA*200 and DA*300. Thus, if ever the SDM of my 50-135 fails, I can always revert back to firmware 1.20 and use it and the DA*200 that I also own with it.
04-19-2009, 07:35 PM   #7
QuoteOriginally posted by SylBer Quote
Hi,
Regards,
RiceHigh's Pentax Blog: How to Get Back to an Older Version of the Firmware?
04-20-2009, 05:15 AM   #8
Thanks for the clarification. So it can be used with older firmware too. I thought it could only work with the latest.
camera, dslr, firmware, lens, photography, sdm
k10D firmware - help! icarus Pentax DSLR Discussion 5 07-27-2008 09:46 PM
K10d firmware dresden_phoenix Pentax DSLR Discussion 26 01-11-2008 04:31 PM
Sigma DG-500 back after firmware update. Very happy. blwnhr Pentax Camera and Field Accessories 11 12-08-2007 05:08 PM
K10d firmware at 1.00 Takman Pentax DSLR Discussion 9 10-26-2007 03:34 PM
k10d firmware 1.2 button Pentax DSLR Discussion 43 04-19-2007 06:14 PM
All times are GMT -7. The time now is 07:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
