I noticed the problem when I put my old M lens on the 100d a few months ago. It stayed wide open no matter what. I've had many helpful people troubleshoot the problem but today, after 3 months, I figured it out.
If you look at the picture you'll see that there's a small black metallic tab on the left side of the lens mount. I figure that this is what moves the blades open and closed since its right by where the lever of a lens would go once you mount it.
What happened tho is that the tab was stuck halfway, leaving the lens open. I was able to "un-stick" it and now the tab stays in that top position the way you see it in the picture. Now when I use the aperture ring I can see the image in the viewfinder lighten or darken depending on the f/stop and it meters correctly. When I turn the ring I can see the blades open and close. Before, it would just stay wide open. The tab also springs back to top if you move it down to that halfway position I found it stuck in. Looks like all is well, right?
But guess what, now the blades stay closed when I put on an A lens or later and have them in A mode. When I look thru the viewfinder while any lens is in A the image is completely dark, like f22. And it meters like its f22 no mater what aperture I dial into the camera. Unless, I use the ring. Ironic, huh?
So, it looks like I traded one problem with another. Ugh. My k200d doesn't have this problem so I'm pretty much sure its a body issue with he 100d.
Looks like I'm going to need it serviced.
