Originally posted by rpriedhorsky Is there a FAQ on this matter somewhere on the site?
Hmmm, that sounds similar to a suggestion I made not long ago. I suggested an FAQ that covered several subjects that come up over and over including K100D batteries (use Eneloops), shutter dead with old manual lenses (use Aperture Ring Optiion), clunking when powered off (normal for SR to flop around), and so on.
alehel: If the K200D uses the same AA batteries as my K1x0Ds and you've had it 14 months I'm amazed you have not had battery problems earlier! As Mark mentioned the NiMh batteries that have trouble in a Pentax may still be suitable in another device. I used to move my "worn out" batteries to my Fuji P&S camera and they work fine there.
If you look through the archive deep enough you will find a person who did some voltage tests. He found the K100D indicates, "Battery Depleted" at a higher voltage than most devices. Standard NiMh batteries start to fade quickly, in fact they fade when not even used (known as self-discharge).
