05-03-2009, 01:00 PM   #1
Spot on my pictures
Hello could someone please help me here, my camera has a dirt particle or something like that and you can see it on the pictures. Here I'm going to post a couple of pictures where you can see it.
Here the spot is on the right.
Here the spot is on the left.
Thank you
05-03-2009, 01:20 PM   #2
Thread moved.
You'll need to clean your sensor by selecting the sensor cleaning option from your camera menu, and then using a rocket blower or something similar to get the dust out of there. If you have a K10D or K20D, you can use the Dust Removal feature to attempt to get rid of the dust particle as well.
05-03-2009, 01:32 PM   #3
Robert S Donovan's Avatar
Assuming these are both uncropped images, I'd have to guess you've got a rather large piece of lint on your sensor that is moving around when the shuttle flaps open. Try the in-camera sensor cleaning shake and then take a few test shots looking for dust (best thing to do is set the aperture to f/22, manually focus at the closest focus setting and take a shot of a blank portion of the daytime sky) and see if you can't correct the problem. Otherwise, you'll need to try the Rocket Bower technique to blast the debris off the sensor. Good luck!
05-03-2009, 09:22 PM   #4
zplus's Avatar
QuoteOriginally posted by Robert S Donovan Quote
Or the first shot was taken with the grip/shutter release at the top of the vertical position and the next shot was taken with the grip/shutter release at the bottom of the vertical position, or vice versa of course.
05-03-2009, 10:20 PM   #5
Robert S Donovan: Assuming these are both uncropped images, I'd have to guess you've got a rather large piece of lint on your sensor ......
I must agree, especially after looking @ the eXIF which shows relatively large apertures used for these samples--f4 & f4.5. Stop that lens down to f8 and smaller and watch the spot grow in intensity for sure.
05-09-2009, 09:02 AM   #6
that is one big, for sure!
Grab a cleaning kit from Pentax, to be sure you get it out. You don't want that thing inside your camera/
camera, dslr, photography, pictures, spot
Nature My Spot...Get out! Gaelen Post Your Photos! 6 03-08-2010 06:38 PM
Abstract Can you spot it? maximm Post Your Photos! 3 01-14-2010 12:47 PM
Dead pixel/white spot on RAW pictures Diasfu Photographic Technique 7 02-12-2009 08:07 AM
Hello, new to the spot dhowler13 Welcomes and Introductions 4 11-20-2008 05:17 AM
Spot on Photo's Fl_Gulfer Photographic Technique 11 12-07-2007 09:41 AM
All times are GMT -7. The time now is 08:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
