05-10-2009, 12:38 PM   #16
Canada_Rockies's Avatar
An often-overlooked fact about Dust Alert is that you have to point at a completely blank featureless surface when performing the check. Otherwise, the system sees the texture of the surface you are point at and misinterprets it as dust on the sensor. The walls of my house are useless for this purpose - far too textured - but blue sky or a sheet of bright white paper are fine.
I do a Dust Alert equivalent with the k10d. I take a picture of a blank sky, infinity focus, f/22, and open the image on the computer. If there are any spots, they will show up then.
05-10-2009, 12:39 PM   #17
Andi Lo's Avatar
Remember that when you use the Pentax cleaning kit, when it says that you should work in a dustless area, you should really work in a dustless area like a washroom, otherwise the sensor will just get dirtier every cleaning, and there's even a chance that you add more dust.
amazon.com, camera, dslr, dust, dustaid, lenspen, photo, photography, sensor
Cleaning a K-X Sensor..... How? Silverkarn Pentax DSLR Discussion 17 09-15-2010 09:08 AM
Sensor cleaning. Modus Operandi Troubleshooting and Beginner Help 17 03-12-2010 04:48 PM
sensor cleaning Dags Pentax DSLR Discussion 12 12-30-2008 10:12 AM
Sensor cleaning: Pec-Pads or Sensor Swabs gadgetnu Pentax Camera and Field Accessories 29 09-24-2007 10:52 AM
Sensor cleaning > Sensor Swab > void warranty? Twinky Pentax DSLR Discussion 2 07-28-2007 01:10 AM
All times are GMT -7. The time now is 10:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
