Originally posted by HermanLee Recently I got to play with a Nikon D700 and a Canon 5DM2 in the store when originally I was just going to test a DA*50-135.
I asked the salesman to put on a prime glass for D700 and he put on an 85mm/1.8.
My K20D has FA 43 Ltd on it.
Both camera set to manual mode, no flash, with f/2 and ISO 3200 because D700 has no Shake Reduction ...go Pentax!
Now let me get this straight. You set both the K20D and the D700 to ISO 3200, because the D700 has no SR, and you did not want to place it at a disadvantage. And then you found that the latter camera has cleaner images with better DR, as best you could judge from looking at LCD monitors on the cameras themselves. This strikes me as having set the K20D to compete on its weakest terms and the D700 on its strongest. But since Pentax's in-camera SR provides 2-3 stops of hand holdability, it would have been reasonable to set its ISO at 800 to 400, in which case the noise and DR differences might not have been so great. At the same time, setting the D700 to the same lower ISOs might have revealed considerable camera shake, if the shutter speeds were sufficiently slow.
One way to conceptualize all of this is that the cameras have different strategies for handling low light situations: The Nikon uses very clean high ISO, and the Pentax uses image stabilization which allows lower ISO and slower shutter speeds. It is possible to buy image stabilized lenses for the Nikon, but they are exceedingly expensive.
Rob
