Using built-in flash on K100d with a manual lens
The other night, I tried to use the built-in flash on the K100d with a Vivitar Series 1 lens for some indoor shots and found that the fastest shutter speed I can have is 1/200. As the flash was more than powerful for what I needed, the only way to correctly expose was by using larger aperture settings. Using the AE-L to have the camera meter for me didn't work as it computed the shutter speed without taking into account that the built-in flash would be in use.
Is there anything that I'm missing when using the built-in flash with a manual lens? Is the limitation on the fastest shutter speed normal?
Fyi, the camera was in the 'M' mode, with the MF and SR on.
Thanks.
