05-14-2009, 02:08 PM   #1
Question about K20D
I've been a Nikon user for many years, but on occasions I use Pentax equipment. I just got K20D off ebay and I like the image quality a lot. I immediately got used to the user interface, but there is one thing I can't figure out. I can't see in the upper LCD the number of images available on the memory card. Does anyone know how to set your K20D to see the empty memory space on the SD card?
Cheers,
Dan
05-14-2009, 02:29 PM   #2
rfortson's Avatar
I believe it's in the Custom Menu settings somewhere. (I know, not very helpful, but at least you get a free bump.)
I do know you can change the top LCD to display various things, one of them being the number of shots remaining.
If all else fails, go into the menu and do a system reset. That should do it.
05-14-2009, 03:03 PM   #3
For me, it usually shows up right when I switch the camera on, in the space where it usually displays ISO. So, if I want to see how many shots I have left, I turn the camera off and turn it back on. But I'm sure there's something else you can do that I just haven't taken the time to discover yet?
05-14-2009, 03:40 PM   #4
madmikess's Avatar
I was just playing around with my K20D. I searched through the menus and didn't find any options. But I do notice that it depends on what mode you have it set to as to whether is hows ISO or # of pics left on your card. Sv,Tv,Av,TAv all show ISO. P,M,B all show # of pics left on card.
05-14-2009, 03:54 PM   #5
Sailor's Avatar
QuoteOriginally posted by madmikess Quote
Interesting. My camera is just the opposite B, M, Av, Tv, P, Green all show shots remaining - which makes more sense when you think about what Sv and TAv do.
Must be something in the menu - but my cursory look didn't turn up anything.
Jer
05-14-2009, 03:55 PM   #6
Dom
Guest
It's number 31 in the 'C' custom menu, if you you can switch it from ISO to shots remaining.
05-14-2009, 05:02 PM   #7
QuoteOriginally posted by ddjchemist Quote
Most likely either you or previous user has set the camera to display ISO instead of shots remaining.
You can see number of shots remaining in some modes by pressing OK button.
05-14-2009, 05:10 PM   #8
Moderator Emeritus
Geez you'd think we were expurts or something. 1 question and 6 different answers. Dom's right but as has often been discussed before, the number is a 'suggestion'. Each shot will have a varied amount of data and can be several Mb's bigger or smaller than the average. You'll think there are 10 shots left on a 4 Gb card and notice the count now shows 22 or whatever. It's not very accurate.
05-14-2009, 05:11 PM   #9
jlp
Additionally, with remaining shots set, pressing the OK button will display the ISO setting. Holding the OK button and while rotating the front e-dial allows you to dynamically change the ISO (from your pre-set value--FN button function.) Pressing the GREEN button while holding the OK in returns to your default setting set using the FN function.
05-14-2009, 07:23 PM   #10
Thank you all, especially Dom. His advice was right. It was a Custom Setting option that needed to be changed.
camera, card, dslr, k20d, memory, photography, user
k20d 1.04 firmware question alfdog Pentax DSLR Discussion 7 05-24-2010 02:04 PM
Question about two cameras K-x and K20D pakuchn Pentax DSLR Discussion 5 12-23-2009 07:53 AM
Two K20D focus question Tom Lee Pentax DSLR Discussion 5 06-30-2009 08:16 PM
Question about K20D or K10D Mystic Pentax DSLR Discussion 3 02-25-2009 12:44 PM
K20D software question Misty Pentax DSLR Discussion 6 02-08-2009 02:53 PM
All times are GMT -7. The time now is 01:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
