04-22-2007, 10:05 AM   #31
QuoteOriginally posted by mattdm Quote
Well, it makes sense to make it optional, and the focus-select mode would override. But I don't think you would change things accidentally as often as all that, because as I noted in the opening post, a single button press doesn't change anything -- once you press fn, then the directional button, you still have to press more buttons to pick your options.
The main issue i would see is that for me and other left eye shooters that i know, when i'm shooting my nose rests against the 4-way button, so it would be a pain to have all the settings reset while i am framing and and shooting, it is bad enough when it changes focus points on me.
The funny thing was i decided to test this i pressed the Fn button to bring up the menu and went about my normal technique and i managed to change my WB setting.
Lastly the flash option in the K10D allows for more then what it does with the DS/L and K100/110 it allows you to set flash compensation, flash modes, rear sync, slow and wireless.
04-22-2007, 10:47 AM   #32
arbutusq's Avatar
I like the Fn button. Quick access to common settings. It isn't as good as my D70 which had button access to ISO, WB and Image Quality. It isn't a deal breaker, just more convenient on Nikon.
I like the menu settings better on Pentax than Olympus as well. They seem to make more sense. Again, not as good as Nikon's but still eminently usable.
04-22-2007, 06:23 PM   #33
khardur's Avatar
QuoteOriginally posted by Skorzen Quote
I think one advantage of the extra button press is that it helps avoid things accidentally getting changed.
Amen to that! Some want direct access buttons - but the Fn button is quick access to shooting-specific functions, and as was said - it would be too easy to screw up the WB (or, worse, change the ISO to 3200 when you wanted 200, for example).
maybe if a new design had a second 4-way directional pad on the upper left somewhere (where a 2nd dial would've been on the top of the camera, for example..)
But the current design suits me just fine.
button, camera, dslr, photography, press
Error "Confirmation" button in marketplace doesn't work with mobile version of site. tendim Site Suggestions and Help 4 12-05-2009 01:13 PM
Winners: Point & Shoot Contest #24 - "The Best View From My Place" rustynail925 Pentax Compact Cameras 7 10-26-2009 12:24 PM
Winners: Point & Shoot Contest #23 - "People" and Pentax Compact Cameras 2 09-26-2009 09:33 AM
Point & Shoot Contest #21 - "How I Spent My Summer Vacation" J.Scott Pentax Compact Cameras 24 08-25-2009 01:04 AM
Point & Shoot Contest #19 "Show off your corner of the world!" Bart Pentax Compact Cameras 24 06-03-2009 05:23 AM
All times are GMT -7. The time now is 12:52 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
