05-17-2009, 05:11 PM   #1
Live View Failure
Has anyone had any trouble with their Live View mode?
I noticed this morning when i try to flick across to live view nothing happens.
Took off the lens and noticed the small lever at left of body moves the full range but the mirror does not move. Annoying even though i don't use it too often i know it will be a major production sending back to the Aus distributor. No problem with any other function.
I was hoping there may be a minor fix, (disloged spring etc) that someone may have knowledge of.
05-17-2009, 06:03 PM   #2
It sounds (if you can read "sounds") like your camera is set on "optical preview". Go in the custom set up menu to line 30 and see where it is. I'm pretty sure you are set on "2 Optical Preview". To use live view, you have to set it on "1 Live View". That should solve your problem.
05-17-2009, 06:24 PM   #3
Flyer, i could kiss you
I don't remember ever changing this but thanks for the reply, needless to say all is again right with the world.
Thanks again.
05-18-2009, 02:55 AM   #4
You're welcome.:ugh: Just forget the kiss.
05-18-2009, 03:10 AM   #5
Mike.P's Avatar
QuoteOriginally posted by marko Quote
I think that's a bit extreme but whatever floats your boat
09-18-2010, 09:03 PM   #6
Thanks!!!!
for older threads
camera, dslr, photography, view
AF in Live View with K-7 Kameraten Pentax DSLR Discussion 11 08-12-2010 09:15 PM
K7 live view sdh87 Pentax DSLR Discussion 3 06-07-2010 10:22 PM
K-7 Live view? redpigeons Pentax DSLR Discussion 9 04-24-2010 06:33 AM
Live view on K-x pingflood Pentax DSLR Discussion 1 11-08-2009 04:40 PM
Another use for Live View Peter Vesuwalla Photographic Technique 4 03-06-2008 11:26 AM
All times are GMT -7. The time now is 11:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
