05-23-2009, 06:44 PM   #1
mattdm's Avatar
1.53 vs. 1.54 (or even 1.57) and actual image size
So, not that I actually care about the tiny fraction of a difference we're talking about here, but I just noticed that in this wikipedia entry
APS-C - Wikipedia, the free encyclopedia
the K20D is listed as having a crop factor of 1.54 rather than the 1.53 listed for all of the other Pentax dSLRs.
Sure enough, the specs give the K20D as having a
23.415.6mm sensor rather than the older 23.515.7. So, that gives 1.5385 instead of 1.5319 horizontally.
But then, there's the issue of _effective_ pixels every dSLR uses some of the edge of the sensor for determining black level, demosaicing the edges, etc. So, I wonder if despite the fractionally smaller sensor chip itself the actual imaging area is identical. I notice that the K10D uses 10.2m of 10.75m actual pixels (5.39% excess) whereas the K20D uses 14.5m of 15.1m (4.14% in excess). Since the fraction is somewhat lower, I speculate that the actual image area is virtually identical.
In fact, assuming that the above percentage of pixels is removed from each, that gives the actual image size for both as about 22.915.3 or a "real" crop factor of 1.57.
(I put "real" in quotes because typical prints crop the edge of 35mm full-frame anyway, and because surely the same issue affects full-frame dSLRs, which also have approximately 5% more photosites than effective pixels.)
It's all really pedantic and doesn't seem even slightly important. Still, I'm curious. Anyone know the answer?
camera, crop, dslr, edge, factor, full-frame, identical, image, issue, k20d, photography, pixels, sensor
Image Size tcwilson Troubleshooting and Beginner Help 6 11-10-2010 07:29 PM
Image Size vs Document Size vs Resolution vs Resampling vs ... AHHHH! veezchick Digital Processing, Software, and Printing 13 08-02-2010 03:57 PM
Image size Jacos Troubleshooting and Beginner Help 15 04-11-2010 02:47 PM
JPEG Image Size hcc Troubleshooting and Beginner Help 21 04-10-2010 08:44 PM
Actual RAW file size and recordable image number Matjazz Pentax DSLR Discussion 12 04-01-2009 04:33 PM
All times are GMT -7. The time now is 09:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
